Aktuelle Zeit: 09 Dez 2025, 00:11
BeitragVerfasst: 11 Jun 2010, 00:45
Seit dem 07.06.2010 ist die erste Version von Timberwolf erschienen, diese setzt OS4.1.2 vorraus.
Bekannte Probleme sind:
There is a number of known problems with this release:
- Menus display correctly (mostly), but selecting items with the mouse
isn't working. Therefore, we recommend using shortcuts (ALT+underlined
letter to open menu, cursor keys to select).
- Some boxes on web pages do not show correctly. They might even destroy
some of the UI elements.
- When launched for the fist time, the window will be taller than the
screen. You'll have to resize it (if you can't reach the size gadget,
use the ctrl+alt key method to resize on any edge of the window)
- Speed is currently much lower than it could be. A conceptual problem
in the rendering code (leading to massive overdraw, sometimes 2 to 8
times) and missing hardware acceleration is responsible for that.
Since we're updating to a newer release of the base source code
(Firefox 3.7), this will be addressed later..
- It crashes a lot. It might even crash when just looking at it. Don't
use it for homebanking yet.
Reporting Bugs
There is a support forum for Timberwolf at http://www.amigans.net.
Please report any bugs that you find. Note that we might not answer
to all of the reports, but we will read and try to address all of them.
Download :arrow: Timberwolf alpha 1
