OEM Version von OS 4.1 für SAM440ep steht unmittelbar bevor
https://forum.amiga-resistance.info/viewtopic.php?f=16&t=1868
Seite 1 von 1
Autor:  HelmutH [ 18 Sep 2008, 07:45 ]
Betreff des Beitrags:  OEM Version von OS 4.1 für SAM440ep steht unmittelbar bevor
Jetzt ist es doch soweit.
OEM Version von AmigaOS 4.1 für SAM440ep steht unmittelbar bevor.
Hier mal ein paar Daten zu verschiedenen Boardvarianten:
Sam440ep TECHNICAL SPECS
Sam440ep is the first modular motherboard produced by ACube Systems Srl.
The main characteristics are:
* low power consumption
* passive cooling
* scalability
The core of the board is the PowerPC 440EP, a System On Chip (SoC) produced by AMCC under license from IBM.
One of the main features of the PowerPC AMCC 440EP is the presence, together with the CPU, of a number of integrated peripherals. This allowed us to build a complete system with a huge savings of both development and debug time, with less components and space used on the PCB. This also results in a significant cost reduction for the customer.
As a consequence the northbridge/southbridge combination is not present on the board. Part of their functionalities are built into the CPU.
The 440EP chip has a size of 35x35 mm, with a PBGA packaging (456 balls). It is built with CMOS (0.13 um) technology, has a very low power consumption (only 3 Watts at 533Mhz) and it does not require any active cooling system.
* MiniITX Form Factor (17x17 cm)
* CPU SoC AMCC 440ep
o Integrated DDR 266 memory controller
o Integrated PCI controller
o Integrated Flash memory devices controller
o Integrated USB 1.1 Host and 2.0 Device controller
o 2 integrated Ethernet 10/100 ports
o Up to 4 serial ports
o 2 I2C interfaces
o SPI interfaces
o 64 pin for I/O General Purpose
* 512 MB DDR soldered onboard (or in alternative a DDR DIMM 100 slot, max 512 MB)
* USB 2.0 OHCI/EHCI NXP PCI controller
* Audio Cirrus Logic CS4281 and Realtek ALC655 Codec
* Silicon Image 4 Serial ATA ports
* ATI RADEON Mobility M9 with 64mb RAM graphic chip
* Pericom 8150B PCI Bridge
* FPGA Lattice XP with 80 pin I/O expansion connector
* PCI Slot - 32 bits, 33 Mhz
* mini PCI Slot - 32 bits, 33 Mhz (optional)
* RTC with backup battery
* UBoot 1.3.1
AVAILABILITY AND PRICE
* Sam440ep is RoHS.
* We strongly suggest to use only DIMM 100, DDR400, 512 Mb 32 bits modules with Nanya chips.
Industrial version - NOW
End user version - NOW
Sam440ep mainboard is available in these configurations:
MAINBOARD ONLY
PRICE
533 Mhz cpu, 512 MB DDR Ram, ATI Radeon M9 64Mb and Audio 5.1 onboard
459,00 euro
332 euro *
667 Mhz cpu, 512 MB DDR Ram, ATI Radeon M9 64Mb and Audio 5.1 onboard
489,00 euro
* this promotion will end on september, 30th!
Sam440ep board with 512 MB DDR Ram, ATI Radeon M9 64MB and Audio 5.1 onboard, SATA DVD-RW, SATA 80 Gb Hard Disk, Logitech Optical Mouse
PRICE
533 Mhz CPU, Psile case (Black or White)
765,00 euro
667 Mhz CPU, Psile case (Black or White)
795,00 euro
533 Mhz CPU, NEXUS AVANCE P002 case
590,00 euro
667 Mhz CPU, NEXUS AVANCE P002 case
620,00 euro
533 Mhz CPU, GA630iBK case
650,00 euro
667 Mhz CPU, GA630iBK case
680,00 euro
Custom configurations are possible by adding/removing the following components:
* ccTalk connector
* SATA connectors
* VGA header
* DVI connector
* LVDS connector
* SmartMedia slot
All prices excluding local taxes and shipping costs from Italy.
For orders please write to: info@acube-systems.com
DRIVER & SOFTWARE DOWNLOAD
* User Manual 0.7
* UBoot 1.2.0 26-Jan-2008 updater ISO
* UBoot 1.2.0 26-Jan-2008 sources
* UBoot 1.3.1 23-Jul-2008 updater ISO
* Linux Kernel 2.6.26-rc2
* Linux Kernel 2.6.26-rc2 md5sum
* Linux Debian Lenny net-install (166.5 MB)
* Linux Debian Lenny net-install md5sum
SAM440ep
Speedtest
Autor:  novamann [ 18 Sep 2008, 18:15 ]
Werd mal morgen bei Vesalia anrufen wann die das Ding (667er) schicken können....
Autor:  HelmutH [ 18 Sep 2008, 20:05 ]
Ich hät da auch interesse dran, zumal wenn man sieht, das die Geschwindigkeit gar nicht so weit unter der eines G4/@800MHz den ich jetzt hab, liegt.
Und wenn das Board gut läuft, hoffe ich ja doch, das dann auch irgendwann Leistungsstärkere folgen werden.
Auf jedenfall mal wieder eine positive Nachricht, so kanns weiter gehn.
Ich halt da auf jedenfall ein Auge mit drauf und sobald ich da was lese, geb ich laut. :)
