Timberwolf alpha 1 (Firefox Portierung) 07.06.10 erschienen https://forum.amiga-resistance.info/viewtopic.php?f=16&t=2834 |
Autor: | HelmutH [ 11 Jun 2010, 00:45 ] |
Betreff des Beitrags: | Timberwolf alpha 1 (Firefox Portierung) 07.06.10 erschienen |
Seit dem 07.06.2010 ist die erste Version von Timberwolf erschienen, diese setzt OS4.1.2 vorraus. Bekannte Probleme sind: There is a number of known problems with this release: - Menus display correctly (mostly), but selecting items with the mouse isn't working. Therefore, we recommend using shortcuts (ALT+underlined letter to open menu, cursor keys to select). - Some boxes on web pages do not show correctly. They might even destroy some of the UI elements. - When launched for the fist time, the window will be taller than the screen. You'll have to resize it (if you can't reach the size gadget, use the ctrl+alt key method to resize on any edge of the window) - Speed is currently much lower than it could be. A conceptual problem in the rendering code (leading to massive overdraw, sometimes 2 to 8 times) and missing hardware acceleration is responsible for that. Since we're updating to a newer release of the base source code (Firefox 3.7), this will be addressed later.. - It crashes a lot. It might even crash when just looking at it. Don't use it for homebanking yet. Reporting Bugs There is a support forum for Timberwolf at http://www.amigans.net. Please report any bugs that you find. Note that we might not answer to all of the reports, but we will read and try to address all of them. Download ![]() |
