Aktuelle Zeit: 13 Dez 2025, 07:41
BeitragVerfasst: 20 Apr 2008, 10:46
Jörg Strohmayer hat auch für das OS3 eine neue Version herraus gebracht.
In der Version V1.3 sind diese Änderungen:
AmigaOS 3.x OWB 1.3 (18.4.2008)
- Ported the memory allocator used in the AmigaOS4 version to AmigaOS
3.x, requires AmigaOS 3.9 BB 2 (exec V45).
- Added more workarounds for bugs in the AmigaOS 3.x SDL library.
- Implemented the font system for AmigaOS 3.x. It's currently limited to
the 3 outline fonts included in AmigaOS 3.x (CGTimes, CGTriumvirate
and LetterGothic).
- Implemented intuition event handling for AmigaOS 3.x, all keys should
work now. Of course text input will always be limited to ISO-8859-1 on
AmigaOS 3.x since it didn't support different charsets yet.
AmigaOS mouse wheel, 4th and 5th mouse button events are supported as
well, but there is probably nothing for AmigaOS 3.x which can generate
them.
- Implemented the graphics device for AmigaOS 3.x, requires Picasso96.
- Implemented a minimal replacement for the missing ICU libraries
(UTF-8, ISO-8859-1 -10 and 13-16).
:arrow: OWB V1.3
