Aktuelle Zeit: 12 Jul 2025, 11:06
BeitragVerfasst: 21 Mai 2006, 14:35
VIA686B onboard AHI Treiber für OS4 / A1 (nicht für microA1!)
description: VIA686B A1 onboard AHI driver
version: 5.7
date: 20060520-13.36
author: Davy Wentzler
submitter: Davy Wentzler
email: info/audio-evolution com
category: driver/audio
replaces: driver/audio/via686b_ahi.lha
requirements: AHI v5 or v6 and AC'97 codec onboard
license: Other
distribute: no
fileid: 1836
hend:
VIA686B onboard AHI driver for OS4 / A1 (not microA1!)
When you're lucky to have an AC'97 audio chip on your
AmigaOne, this driver will let you use the audio connectors
on the back of your motherboard. Only the first batch(es)
of A1's (not microA1's!) contain this chip. You either have
a Sigmatel chip or an empty square left to your AGP slot
under your gfx card.
History:
5.7 (01 May 2006)
- Stephen Brookes: Fixed bug in s/g table which could cause
a crash at the start of playback.
- Stephen Brookes: Fixed 'half-rate' audio problem which could
occur because the AC'97 wasn't always reset properly.
Download: via686b_ahi.lha
