Aktuelle Zeit: 17 Sep 2026, 03:45
BeitragVerfasst: 19 Mär 2009, 10:40
> I hope this is the correct palce to notify you of a
> mistake in the data. The Progressive Peripherals &
> Software EXP-1000 is listed as a trapdoor RAM expansion for
> the A500 and/or A500+. This is not a trapdoor device! It is
> installed under the CPU of the A500.
> > > I hope this helps.
> > > Sincerely,
