Aktuelle Zeit: 13 Dez 2025, 10:29
BeitragVerfasst: 13 Aug 2010, 12:35
19.05.2007 CollageBlanker V1.7
This is a Collage Picture Blanker from PEB.
History:
*Version 1.7 (5/19/07):
Added a version that will fit itself to your current screen's resolution (this will accommodate wide screens).
*Version 1.6 (3/30/07):
Added a filter so that non-picture files (such as icons) in the picture drawer will not interfere with CollageBlanker
Added the option of recursive directory scanning, so that the pictures in subdirectories can also be used by CollageBlanker
*Version 1.5 :
Added a couple more options in Preferences (including being able to choose to use a different picture drawer, the ability to have shadows on or off, the choice of a solid color or a pattern for the picture boarders)
*Version 1.1:
Fixed a problem with the 1024x768 version
*Version 1.0:
First attempt
