Aktuelle Zeit: 07 Sep 2025, 00:40
Ein neues Thema erstellen  Auf das Thema antworten  [ 54 Beiträge ]  Gehe zu Seite « 1 2 3 4
 Betreff des Beitrags: Jack V4.3 (29.12.2013)[OS4]
BeitragVerfasst: 30 Dez 2013, 22:51
29.12.2013 Jack V4.3 [OS4]
Version 4.3 mit diesen Änderungen:
* Filemanager: APPDIR: appeared under 'Drives', identified found elsewhere in
4.0.9 and removed. I am certain APPDIR: never appeared in the output of C:Info
in previous versions of the OS. This seems to stem from a system update as
APPDIR: is now accessible from the shell as well.
* Dashboard: Clicking the 'Go' button works again if the URL in the field is
valid.
* Dashboard: New Tab Added showing some Tech RSS NewsFeeds including AmigaWorld
and officialHyperion Entertainment feeds.
* Knowledge Base: Fixed 'Go to website' button.
 Betreff des Beitrags: Jack V4.4 (20.01.2014)[OS4]
BeitragVerfasst: 20 Jan 2014, 23:11
20.01.2014 Jack V4.4 [OS4]
Änderungen in V4.4:
* Knowledge Base: Switched from Double-click events on both listviews to active selection.
* Dashboard: Reorganised buttons into a listview as a better layout solution.
* News: Added new column at beginning of listview to show icon against each entry on the list.
* News: A new window created that allows you to add, edit or remove RSS Feeds.
* Corrections to GetDevices(), no problems with Path row data in the Search window. As a result the Context menus options working again.
 Betreff des Beitrags: Jack V4.5 (03.03.2014)[OS4]
BeitragVerfasst: 03 Mär 2014, 16:27
03.03.2014 Jack V4.5 [OS4]
* Special OS4 Kernal update release. Fixes issues surrounding DownloadFile().
Thanks must go to Andreas Falkenhahn for supplying an intermediatory release.
* Minor: Domain name changes.
 Betreff des Beitrags: Jack V4.6 (11.10.2014)[OS4]
BeitragVerfasst: 22 Nov 2014, 14:58
11.10.2014 Jack V4.6 [OS4]
Änderungen seit V4.5:
* AppStore Bundles tab - this has been re-factored. Replaced the previous
layout with a listview - this will allow the interface to re-size better.
I found this after changing to a monitor with a lower 4:3 resolution, the store
window simply refused to open.
MUI Royale 1.1 update, change list:
* Promote to Screen: All child windows will now correctly follow the main
dashboard to the selected screen.
* Execute Command menu item: Pressing Enter on Keyboard will Advance focus to
next gadget in Window.
* Column sorting implemented as per imposed HW algorithm which is very basic
MUI Royale 1.2 update, change list:
* Introduction of Icon Tabs
* Introduction of sortable columns on listviews, works on almost all listviews
* Quiet refresh enabled during listview column sort, leads to smarter/quicker
sort and refresh
 Betreff des Beitrags: Jack V4.7 (11.11.2014)[OS4]
BeitragVerfasst: 22 Nov 2014, 15:01
11.11.2014 Jack V4.7 [OS4]
Änderungen seit Version 4.6:
* Added latest version of MUI Royale into the distribution - should have been in 4.5 but was missing.
* Further sanity check of AISS version installed by user.
* Expanded action description for when second instance of Jack occurs.
* Removed Python installation instructions from Installer script.
 Betreff des Beitrags: Jack V5.0 (07.11.2015)[OS4]
BeitragVerfasst: 07 Nov 2015, 21:08
07.11.2015 Jack V5.0 [OS4]
Änderungen in dieser Version:
* Jack ist jetzt auch im App-Store, mit einer nicht-Shop Verwandten, separaten Anwendung Namens Jill,
* hinzugefügt: Prozentuales herunterladen zum Download Manager,
* entfernt: App-Werbung,
* erkennt "Final Edition" in veröffentlichten Gemeinschafts Statistiken,
* erkennt "AmigaOne X5000" in veröffentlichten Gemeinschafts Statistiken,
* sucht Geräte deren Position sich über den oberen Rand des Fensters bewegt hat,
* hinzugefügt: Icons für Software und Hardware in veröffentlichten Gemeinschafts Statistiken.
Ich hoffe ich hab das einigermassen vernünftig übertsetzt bekommen. Ist echt ätzned was da manchmal beim google Übersetzer raus kommt. Also helft mir ruhig wenn da was nicht stimmt.
Changes in this version:
* Jack is now just the App-Store, with everything non-Store related becoming a separate application called Jill.
* Added download percentiles to the Download Manager
* Removed in-app advertising
* Recognises 'Final Edition' release in Community Stats
* Recognises 'AmigaOne X5000' release in Community Stats
* Search gadget moved to a wider position extending across the top of the window
* Added icons for Software and Hardware in Community Stats
 Betreff des Beitrags: Jack V5.1 (29.12.2015)[OS4]
BeitragVerfasst: 29 Dez 2015, 21:08
29.12.2015 Jack V5.1 [OS4] von Richard Lake
Neuerung in dieser Version:
- erkennt "AmigaOne A1222" Hardware-in Community Statistiken.
 Betreff des Beitrags: Jack V5.2 (15.01.2016)[OS4]
BeitragVerfasst: 16 Jan 2016, 23:39
15.01.2016 Jack V5.2 [OS4] von Richard Lake
Änderung in dieser Version:
- Fehler behoben: der beim analysieren von Gemeinschaftsstatistik Daten entstand (gemeldet von Niclas Eriksson)
BeitragVerfasst: 20 Mär 2016, 13:18
20.03.2016 Jack 5.2 - Server Migration
djrikki auf http://www.amigaworld.net/
Kurze Info zu Jack für AmigaOS.
Dateien und die Benutzer-Datenbank wurden auf die neue Serverlösung übertragen.
Ältere Versionen von Jack werden nicht mehr funktionieren, besorgt Euch die aktuellste Version im OS4Depot.net
Jack in Facebook: http://www.facebook.com/jackforamigaos
