hw_app_template V1.3 (13.12.2012)[OS4]
https://forum.amiga-resistance.info/viewtopic.php?f=67&t=3141
Seite 1 von 1
Autor:  HelmutH [ 20 Jun 2011, 20:49 ]
Betreff des Beitrags:  hw_app_template V1.3 (13.12.2012)[OS4]
07.06.2011 hw_app_template V0.1 [OS4]
Anforderungen: Hollywood 4.7+
Version 0.1
drawUI() - Refreshing your display
RoundTo() - Round a float to a number of decimal places
p_Hms - Convert seconds to Hours, Minutes and Seconds
p_milliseconds - Convert milliseconds into Days, Hours, Minutes and Seconds
p_urlUncode - Uncode any URL into regular text
p_htmlUncode - Uncode a line of text containing HTML Escape Codes
p_getXmlString - Get a string from a particular key in an XML file
p_getXmlInteger - Get an integer from a particular key in an XML file
p_getXmlDate - Get a date from a particular key in an XML file
p_sendRexxMessage - Send a Rexx Message to Ringhio to display a notification.
p_sendRexxMessage - Send a Rexx Message to the Workbench to open a drawer
p_convertByes - Convert a filesize written in bytes to written notation
p_setFont - Useful short function to set common font properties
Autor:  HelmutH [ 18 Okt 2011, 19:27 ]
Betreff des Beitrags:  Hollywood Common Functions V0.5 (17.10.2011)[OS4]
17.10.2011 hw_app_template V0.5
Minor bug fix. Correction to numeric fields when entering 0. Added executable
into distribution.
13.10.2011 hw_app_template V0.4
1 - p_StringRequest is a complete replacement for StringRequest(). With it you
can insert TextFields into a window directly (hallelujah!).
Features:
* Mark text (works with keyboard only atm, mouse support will be added later)
* Cut, Copy and Paste
* Field Type: Number or Text
* Number fields have 'Spinboxes' next to them with wheel-support
* Number fields, you can specify min and max values
* Text fields can easily be defined as password fields with correct asterisk
masking on-screen
* Text fields, possible to define whether a string is REQUIRED or OPTIONAL
* Text fields, placeholder text is possible - *think HTML5*
A COMPLETE WORKING EXAMPLE OF p_StringRequest IS INCLUDED IN THIS PACKAGE
2 - The function p_CreateButton has been updated, buttons now look much more
like native AmigaOS buttons than they did before.
06.10.2011 hw_app_template V0.3
xx.xx.2011 hw_app_template V0.2
Autor:  p-OS [ 29 Feb 2012, 20:58 ]
Betreff des Beitrags:  Re: Hollywood Common Functions V0.5 (17.10.2011)[OS4]
Das ganze heißt mittlerweile hw_app_template und befindet sich in Version 0.7 hier: http://os4depot.net/share/development/e ... mplate.lha
Autor:  HelmutH [ 01 Mär 2012, 19:44 ]
Betreff des Beitrags:  hw_app_template V0.7 (05.01.2012)[OS4]
Danke für den Hinweis p-OS, ich hab es geändert und auch hier mal nachgetragen. :wink:
05.01.2012 hw_app_template V0.7
Änderungen in V0.7
Applet changed to Base Library; all function calls are object function-based
Bug fixes - Trailing zeroes when set to False now work in numeric fields now
work correctly when using spinboxes/mouse wheel
You can now create Option Boxes, an example not shown in this update, will come
in future update.
30.10.2011 hw_app_template V0.6
Änderungen in V0.6
This is a complete re-write of TextEntry. The application and archive are now
called Hollywood Application Template (HAT) as that is what it is now.
With HAT you can now go ahead and build your very own applications much more
comprehensively. By studying the code you will learn how messages are sent from
windows, buttons, textfields and icons and hopefully go ahead and produce the
next 'killer' ^.^ application written in Hollywood.
In the future I may well add support for other GUI objects such as Listviews and
what not. But for now there should be enough in HAT to get YOU started.
TextField Features:
masking on-screen
This is a collection of common functions that can easily be added into your
Hollywood applications and games.
Autor:  HelmutH [ 13 Dez 2012, 21:17 ]
Betreff des Beitrags:  Re: hw_app_template V0.7 (05.01.2012)[OS4]
13.12.2012 hw_app_template V1.3
1.3 Änderungen
Bug fixes, tightening code in keyboardshortcuts and toolbar in order to reduce
necessity to edit these files.
Imported more functions from Jack:
* Asynchronous Downloading
* Capitalise First Letter
* GetAvailableMemory, GetOperatingSystem (AmigaOS Version too), GetCPU
* GetIPAddress, GetLocalIP, IsOnline
* EncodeURL, DecodeURL
