Aktuelle Zeit: 25 Jun 2025, 05:30
 Betreff des Beitrags: Bef V1.1 (02.03.2010)[OS4]
BeitragVerfasst: 09 Feb 2010, 13:35
06.02.2010 Bef V1.0 [OS4]
Alfkil Thorbjørn Wennermark stellt die erste Version von Bef = BE Fighters 2010 Edition ins OS4Depot.
Hierbei handelt es sich um ein Kampfsportspiel mit "echten" digitalisierten Kämpfern.
 Betreff des Beitrags: Bef V1.01 (08.02.2010)[OS4]
BeitragVerfasst: 09 Feb 2010, 13:36
08.02.2010 Bef V1.01 [OS4]
Dies wurde in der neuen Version 1.01 geändert.
Version 1.01: (Only Amiga OS 4 version) Made with Hollywood.
- I accidentally messed up my own character trying to fix the memory problem before uploading the first version to os4depot. Sorry about that! This upload fixes the problem.
BeitragVerfasst: 03 Mär 2010, 11:13
02.03.2010 Bef V1.1 [OS4]
Änderung in Version 1.1: (All versions)
- Switched the whole in game gfx engine to use layers
instead of sprites. By doing this I was able to reduce the memory
requirements from almost 1 GB (!) down to around 256 MB. Some
combinations of players will only work on 300 BM and above,
especially the "alf" character uses more memory than the rest.
