Bef V1.1 (02.03.2010)[OS4]
https://forum.amiga-resistance.info/viewtopic.php?f=68&t=2764
Seite 1 von 1
Autor:  HelmutH [ 09 Feb 2010, 13:35 ]
Betreff des Beitrags:  Bef V1.1 (02.03.2010)[OS4]
06.02.2010 Bef V1.0 [OS4]
Alfkil Thorbjørn Wennermark stellt die erste Version von Bef = BE Fighters 2010 Edition ins OS4Depot.
Hierbei handelt es sich um ein Kampfsportspiel mit "echten" digitalisierten Kämpfern.
Autor:  HelmutH [ 09 Feb 2010, 13:36 ]
Betreff des Beitrags:  Bef V1.01 (08.02.2010)[OS4]
08.02.2010 Bef V1.01 [OS4]
Dies wurde in der neuen Version 1.01 geändert.
Version 1.01: (Only Amiga OS 4 version) Made with Hollywood.
- I accidentally messed up my own character trying to fix the memory problem before uploading the first version to os4depot. Sorry about that! This upload fixes the problem.
Autor:  HelmutH [ 03 Mär 2010, 11:13 ]
02.03.2010 Bef V1.1 [OS4]
Änderung in Version 1.1: (All versions)
- Switched the whole in game gfx engine to use layers
instead of sprites. By doing this I was able to reduce the memory
requirements from almost 1 GB (!) down to around 256 MB. Some
combinations of players will only work on 300 BM and above,
especially the "alf" character uses more memory than the rest.
