Aktuelle Zeit: 19 Sep 2026, 21:36
BeitragVerfasst: 07 Jun 2015, 17:44
07.06.2015 GL Galore 1.0 [OS3 FPU, OS4, MOS, ...]
Das neue GL Galore-Plugin läutet eine Zeitenwende ein, denn damit ist nun endlich eine hardware-gestützte 3D-Programmierung mit Hollywood auf Basis von OpenGL® möglich.
BeitragVerfasst: 21 Mai 2017, 11:25
21.05.2017 GL Galore 1.1 [OS3 FPU, OS4, MOS und AROS]
- Change: Updated documentation
- New: Added \@2x graphics for high resolutions systems on Windows and Mac OS
- New: Added 64-bit builds for Windows, Linux, and Mac OS
- New: Added Linux ARM build; note that the Raspberry Pi currently only comes with an experimental
OpenGL driver which is disabled by default; to enable it, you need to open raspi-config, go
to "Advanced Options", enable it and reboot
- New: Added the following functions for polling joystick input through GLFW: glfw.JoystickPresent(),
glfw.GetJoystickButtons(), glfw.GetJoystickAxes(), and glfw.GetJoystickName(); these can be
useful because there are much more flexible than Hollywood's inbuilt joystick library which is
very Amiga-centric and was mainly designed for 1980s-style joysticks
- Fix: Cube.hws and MultiDisplays.hws didn't call CheckEvent()
- New: Added support for Hollywood 7's new FULLSCREENSCALE mode
- New: Added help strings for GL Galore's commands; if you have Hollywood 7, you will now get
function help with Hollywood's IDE for Windows and you can also press F1 to open the GL Galore
reference; note that you need to copy GLGalore.chm to the "Docs" directory of your Hollywood
installation directory for this to work
- Fix: glu.Build3DMipmaps(), glu.UnProject(), and gl.GetCurrentContext() were not documented
- New: Added Unicode support if Hollywood 7 is available; you can use the new "VanillaKey" event
handler to listen to Unicode keys
- Fix [Amiga]: GL Galore no longer crashes when started in full screen mode and the GL context
couldn't be initialized, e.g. because of missing drivers (reported by Redlion)
- Change [Win32]: Flip() uses a different vertical synchronization mechanism now that prevents
tearing on some systems
- Fix: Plugin initialization code didn't balance the stack after it was done
BeitragVerfasst: 08 Jan 2021, 19:58
16.03.2020 GlGalore V1.1 Deutsches Handbuch verfügbar.
