Aktuelle Zeit: 10 Mär 2026, 15:30
Ein neues Thema erstellen  Auf das Thema antworten  [ 47 Beiträge ]  Gehe zu Seite « 1 2 3 4 »
BeitragVerfasst: 02 Mär 2013, 15:35
09.02.2013 VAMP V0.93B [OS3, OS4, MOS, AROS + WIN]
Änderung in Version 0.93 B (09.02.2013)
- New compilation to use the new Hollywood plugin apng to play the png web animations.
BeitragVerfasst: 12 Apr 2013, 20:03
27.03.2013 VAMP V0.94 [OS3, OS4, MOS, AROS + WIN]
Änderungen in V0.94
- Corrected the information of width and height from pictures.
- Corrected the information of file size, now this information is showed in Kbytes, MBytes and GBytes.
- Solved the problem with the PNG mouse pointer under Amiga OS 3.5-3.9, now VAMP uses the Workbench iff mouse pointer.
- Add the option to choose your language in the messages and menus.
- Corrected the stopped bug when you load a new movie and the previous has finished.
- Add support to jpeg 2000 graphic format.
- Remove the V.A.M.P.'s mouse pointer, again now it use from system default pointer.
BeitragVerfasst: 11 Mai 2013, 18:01
20.04.2013 VAMP V0.94B [OS3, OS4, MOS, AROS + WIN]
- Unterstützt das TIFF Grafik Format.
BeitragVerfasst: 01 Aug 2013, 21:23
02.08.2013 VAMP V0.95 [OS3, OS4, MOS, AROS + WIN]
Dies sind die Änderungen in V0.95:
- Compiled with the lastest Hollywood 5.3.
- Suppressed the text message with the % of volume bar.
- Fixed the bug that was preventing the repeating the multimedia file.
- Again available the autoplay video and song when you have loaded the file.
- Corrected the rewind/forward video&song time with the mouse wheel, now it is second
to second.
- Improvement the player GUI, new button Mute OFF for the option Mute ON/OFF.
BeitragVerfasst: 22 Aug 2013, 18:51
22.08.2013 VAMP V0.96 [OS3, OS4, MOS, AROS + WIN]
Änderungen in V0.96:
- Problem mit dem neuen Knopf Mute OFF für die Option Mute ON/OFF behoben.
BeitragVerfasst: 28 Sep 2013, 19:33
22.09.2013 VAMP V0.97 [OS3, OS4, MOS, AROS + WIN]
Änderungen in V0.97:
- Neue Sprache verfügbar: Schwedisch
BeitragVerfasst: 13 Okt 2013, 18:09
03.10.2013 VAMP V1.00 [OS3, OS4, MOS, AROS + WIN]
Änderungen in dieser Version:
- Fixed the bugs handling loading pictures, now if you click on the player buttons
the picture doesn't disappear.
Also if you load an Amiga animation the previous picture loaded isn't show instead
of player skin.
- New audio format support using the Hollywood plugins the format m4a used for iTunes.
- Recoded the source code for Amiga systems.
- Recoded the source code for the language translations.
BeitragVerfasst: 30 Dez 2013, 22:27
18.12.2013 VAMP V1.05 [OS3, OS4, MOS, AROS + WIN]
Änderungen in V1.05
- Support of video format m4v from Apple, using Hollywood™plugins or video codecs.
- Fixed a bug in time uncounter of movie or song, now added the seconds too.
- Added in information box the end time playback for movies.
BeitragVerfasst: 30 Dez 2013, 22:29
24.12.2013 VAMP V1.06 [OS3, OS4, MOS, AROS + WIN]
In Version 1.06 würde dies geändert:
- Corrected the playing clock, now with T-t key, you can choose between count or dis count time.
BeitragVerfasst: 19 Jan 2014, 23:21
06.01.2014 VAMP V1.07 [OS3, OS4, MOS, AROS + WIN]
- Refixed the bug with End Time Playback.
- Add the option to rise or lower the FPS in the animations with UP/DOWN arrow keys, suggestion from Brent Santin.
BeitragVerfasst: 26 Jan 2014, 17:31
25.01.2014 VAMP V1.08 [OS3, OS4, MOS, AROS + WIN]
Änderungen in V1.08 sind:
- The player shows the frame number playing for animations.
- Fixed the player playing animations.
- Fixed some bugs in the box info.
- Corrected some text strings of finish translation by Markku Heikkinen.
BeitragVerfasst: 08 Jan 2015, 19:08
25.03.2014 VAMP V1.10 [OS3, OS4, MOS, AROS + WIN]
Ist mir irgendwie durchgerutscht diese Version.
Neuerungen in V1.10:
- Neue Sprache verfügbar: Polnisch von Czesiu Mnich.
- Einen Fehler in der Info-Box bei der Videogröße korrigiert, Anregung von Czesiu Mnich.
- Spielen von YAFA und DigiBooster Formate durch Hollywood-Plugins.
Changes in V1.10:
- New translation available: Polish from Czesiu Mnich.
- Corrected a mistake in the movie size info box, suggestion from Czesiu Mnich.
- Playing of YAFA and DigiBooster formats using Hollywood plugins
BeitragVerfasst: 22 Feb 2015, 15:15
22.02.2015 VAMP V1.25 [OS3, OS4, MOS, AROS + WIN]
Erhältlich ist die neue Version 1.25 mit diesen Verbesserungen:
- Fehler in der Routine, um große Bilder im VAMP Fenster anzuzeigen behoben.
- Fehler beim Sound im Meldungsfenster behoben.
- Fehler beim abspielen von Hively Tracker ™ Format "HVL" mit Hollywood-Plugin behoben.
- Neue Konfigurationsdatei für die Windows-Version.
- Einige kleinere Fehler behoben.
Available the new version 1.25 with the next improvements:
- Fixed the routine to show big pictures inside V.A.M.P.'s window.
- Sound in the message windows.
- Playing of Hively Tracker™ format "hvl" using Hollywood plugin.
- New configuration file for Windows version.
- Some littlest bugs fixed.
 Betreff des Beitrags: VAMP V1.30 (30.05.2015) [OS4]
BeitragVerfasst: 02 Jun 2015, 17:56
30.05.2015 VAMP V1.30 [OS4]
Für OS4 ist die Version V1.30 mit diesen Änderungen erschienen:
- Kompiliert mit der letzten Hollywood v6.00 Epiphany Version.
- Behoben: Programmkonfigurationsdatei Tabelle.
BeitragVerfasst: 14 Jun 2015, 16:30
14.06.2015 VAMP V1.35 [OS3, OS4, WOS, MOS, ...]
Version V1.35 mit dieser Änderung:
- Bildschirmfotos können jetzt in der Standard-Schublade im Programm oder in der Schublade die Sie auswählen gespeichert werden, die standardmäßig Schublade ist jetzt die INI-Datei.
