Aktuelle Zeit: 13 Sep 2026, 18:08
Ein neues Thema erstellen  Auf das Thema antworten  [ 29 Beiträge ]  Gehe zu Seite « 1 2
BeitragVerfasst: 12 Jun 2010, 17:57
12.06.2010 LoView V1.85
In Version 1.85 von LoView hat Simone"Tuxedo"Monsignori diese Änderungen gemacht:
- Fixed one nasty bug that prevent the full activation of LoView if you load a file from the Default Tool,
- Added a nice ARexx port(ATM primarly to be used,
- toghter the LoViewThumb program,
- now LoView was a mini-suite that consists of 3 exe.
BeitragVerfasst: 03 Jul 2010, 18:30
Hab mal einen Screenshot oben drangehängt.
Bilder sagen doch mehr als Worte. :wink:
BeitragVerfasst: 07 Dez 2010, 15:18
15.08.2010 LoView V1.86
In der neuen Version hat Simone"Tuxedo"Monsignori dies geändert.
- Fixed a weird bug that crash LoView if some weird Exif data was passed...
BeitragVerfasst: 07 Dez 2010, 15:21
07.12.2010 LoView V2.00
Und heute hat Simone"Tuxedo"Monsignori die Version 2.00 mit diesen Änderungen bereit gestellt.
- Added a key file support,
- removed a nasty bug that cause a crash if the SlideShow was stopped a soon as was started,
- added Bufferd display so now you dont see anymore the ugly "clear" effect when switching from a picture to another.
BeitragVerfasst: 10 Mär 2011, 11:11
13.12.2010 LoView V2.05 [OS4] OS4Depot
23.12.2010 LoView V2.05 [OS3, OS4, MOS + WOS] Aminet
31.12.2010 LoView V2.05 [AROS] Aminet
Änderungen in V2.05 zur Vorversion:
- Corrected a bug in the Exif loader and added a shell argument to LoViewThumb (the "-dir" parameter) to load directly the path you like without have the requester popping up,
- fixed a bug in SlideShow with only one picture loaded (much than a fix that was a quick workaround until
next major release)...
BeitragVerfasst: 01 Jan 2012, 14:40
31.12.2011 LoView V2.35 [OS3, OS4, MOS, WOS + AROS]
31.12.2011 v2.35
- Added Exif data save in jpeg saved pictures(the data will be saved as the original),
- now you can use LoView as icon on AmiDock and drag a file to it to show it,
- now you can select some files in LoViewThumb and send all them all to LoView,
- a nice hand pointer was now displayd while panning images,
- added a tiny edit window, some bugfixes.
 Betreff des Beitrags: LoView V2.37 (10.01.2012)[OS4]
BeitragVerfasst: 29 Jan 2012, 13:24
10.01.2012 LoView V2.37 [OS4]
Änderungen in V2.37 sind:
- Added a ContextMenu entry("Open > Thumb") to open current displayed pic dir in LoViewThumb, Added a .info
- filter option to avoid LoView/LoViewThumb to load info files,
- fixed some bugs,
- added new perfs to Pop To Front LoView or LoViewThumb when sending thumbs/image from one to another task.
Die neue Version ist bisher nur für OS4 aktualisiert worden.
 Betreff des Beitrags: LoView V2.50 (16.05.2012)[OS4]
BeitragVerfasst: 01 Jul 2012, 12:30
16.05.2012 LoView V2.50 [OS4]
Die neue Version 2.50 enhält diese Änderungen:
- Reverted to old behaviour in save images,
- added some new image effects,
- added video support,
- added "Save" and "ReSize" voices in the ContextMenu,
- added new TooolTypes for VideoSupport and Volume default
- value and select/remember music load dir and for decide the LoView behaviour when pressing the "ZoomToReal" button,
- added New "ASK" parameter for SLIDESHOW_TIME ToolType,
- LoViewThumb now can save the selected thumbs in the image format you like,
- in LoViewThumb now you can select the iBatch mode for usage of the thumber with iBatch,
- in LoViewThumb now you can batch resize selected images in a desired percentage,
- bug fixes as usual.
 Betreff des Beitrags: LoView V2.51 (25.05.2012)[OS4]
BeitragVerfasst: 01 Jul 2012, 12:57
25.05.2012 LoView V2.51 [OS4]
In Version 2.51 wurde dies geändert:
- Fixed some annoing and rare bugs.
 Betreff des Beitrags: LoView V2.80 (26.04.2015)[OS4]
BeitragVerfasst: 26 Apr 2015, 10:12
26.04.2015 LoView V2.80 [OS4]
Simone Monsignori "Tuxedo" hat eine neue Version von LoView erstellt, mit diesen Änderungen:
- Fixed some really annoing bugs,
- Reworked Exif reading routine with support for some Pentax Makernote TAGs and added some new more standard TAGs to be swhown,
- Added a complete preferences editor with also an easy installation procedure,
- now the LoView menu was a system friendly menu when LoView works in windowed mode,
- now preferences was stored in ENVARC:LoView/ and no more in the LoView icon(the old ones can be imported from old LoView icon while installing),
- The SlideShow routine was now completely reworked to grant the user a full immersive new mode(now you can switch SlideShow in complete FullScreen and change also backgroun color if you like)so you can nicely slide your honeymoon or trips or whatever you like photos to your friends/parents with your Amiga on your home TV :),
- Added a NEW prefs "Load ALL" that can be selected to pass the entire file list to LoView without pre-scan directory for valid files in that way the image will be loaded same time than with SinlgePic pref selected but you have the whole filelist available in the Jump To window to choose(wrong files will be eliminated while loading),
- now the Crop function dont draws a fixed crop area but that can be resized clicking on the bordes while appear the hand-pointer,
- Added the new preferences NoOutpuError that skips silently unsupported files(really usefull if you load huge directory with not so much supported files and use toghter the LoadALL preferences),
- added iconify functionality from the menu,
- added the ability to drag drawers over the LoView icon in AmyDock instead of only single files.
*** The LoView experience was now 10/15% faster thanks to new Hollywood 6!
 Betreff des Beitrags: LoView V2.85 (26.05.2015)[OS4]
BeitragVerfasst: 26 Mai 2015, 21:03
26.05.2015 LoView V2.85 [OS4]
Neue Version mit diesen Änderungen:
Einige lästige Fehler behoben, und 3 neue Einstellungen zum auswählen aufgenommen:
1 - Verwendung eines Internen oder Externen JPEG Loader,
2 - die Einstellung wird automatisch beim Beenden gespeichert,
3 - Eine Opus5 Kompatibilitätsoption hinzugefügt.
BeitragVerfasst: 30 Jun 2015, 19:43
26.06.2015 LoView V2.90 [OS3, OS4, MOS, WOS, AROS]
In Version 2.90 wurden diese Änderungen gemacht:
- Einige lästige Bugs behoben und
- verbesserte Benutzerfreundlichkeit in einigen Programm, Nummerierung und Umbenennung mit Thumber und
- hinzugefügt, neue Tooltypes für LoViewThumb um Opus5 im Kompatibilitätsmodus zu starten.
 Betreff des Beitrags: LoView V2.91 (30.12.2015)[OS4]
BeitragVerfasst: 03 Jan 2016, 18:16
30.12.2015 LoView V2.91 [OS4] von Simone Monsignori (Tuxedo)
Simone hat für OS4 eine neue Version von LoView im OS4Depot mit diesen Änderungen bereit gestellt:
- Fehler behoben, der das auswählen der zweiten Funktion verhindert, für Tasten mit 2 Funktionen in LoView,
- eine Ringhio Benachrichtigung (nur OS4) hinzugefügt, wenn bei den LoView Miniaturbilder die ausgewählten Miniaturbilder fertig geladen wurden.
 Betreff des Beitrags: LoView 2024 (08.12.2024)[OS4]
BeitragVerfasst: 22 Dez 2024, 18:38
08.12.2024 LoView 2024 [OS4] von Simone Monsignori (Tuxedo)
***WICHTIG***
Beachtet, dass die "2024" Version von LoView auf der Version 2.85 basiert, da ich (Simone Monsignori (Tuxedo) durch einen Festplattencrash die älteren Versionen verloren habe. Wenn Sie also die Version 2.91 verwenden und diese Version ausprobieren
und feststellen, dass Sie eine Funktion vermissen die mit 2.91 zusammenhingen, müssen Sie leider weiterhin die 2.91 verwenden.
...BTW nicht mischen (d.h. zusammen starten), das kann zu seltsamem Verhalten führen...am besten ist es
die 2.91 komplett zu entfernen und "2024" zu verwenden wenn möglich/sie mögen.
- Ein Fehler wurde behoben, der das JumpTo-Fenster nicht korrekt aktualisierte, wenn eine Datei gelöscht oder verschoben wurde,
[Viewer] - Fehler behoben der das Bild nicht in der richtigen Exif-Ausrichtung anzeigt,
[Viewer] - Fehler im Prefs-Editor behoben, der das korrekte Speichern von Dateipfaden verhinderte,
[Viewer] - einige kleinere Fehler behoben,
[Viewer und Thumber]- eine vollständige ".info"-Datei-Erkennung, die es dem Programm erlaubt, Icon Bilddateien zusammen zu kopieren/verschieben/umzubenennen/löschen,
[Nur Viewer], Ein seltsames Verhalten wurde behoben, das die ".info"-Dateien beim Laden eines Verzeichnisses nicht filtert, ohne die
Dateien auf echte Bilder zu prüfen,
[Viewer] - Hinzufügen eines Benachrichtigungs-Pop-Up auf LoViewThumb hinzugefügt, um anzuzeigen, wenn Thumb Load und andere Aktionen wie Kopieren/Umbenennen/etc beendet wurden,
- behoben das Pop-Up-Menü, das die Verwendung der "Rechtsklick"-Optionen auf einigen LoView
Schaltflächen.
