Aktuelle Zeit: 16 Sep 2026, 08:14
BeitragVerfasst: 03 Jan 2009, 15:46
Vom neuen SAM Board SAM440ep-flex sind Spezifikationen, Preis und Photo veröffentlicht worden.
* FlexATX Form Factor (21.6 x 17 cm)
* CPU SoC AMCC 440ep (400, 533 or 667 Mhz)
o Integrated DDR 266 mhz memory controller
o Integrated PCI controller
o Integrated Flash memory devices controller
o Integrated USB 1.1 Host and 2.0 Device controller
o 2x integrated Ethernet 10/100 ports
o Up to 4 serial ports
o 2x I2C interfaces
o SPI interface
o 64 pin for I/O General Purpose
* 2x DDR DIMM 100 slots, max 1 GB RAM
* USB 2.0 OHCI/EHCI NEC PCI controller (2x external ports, 2x internal ports)
* Audio Cirrus Logic CS4281 and Realtek ALC655 Codec
* Silicon Image 4x Serial ATA ports
* Pericom 8150B PCI Bridge
* FPGA Lattice XP with 80 pin I/O expansion connector
* 1x PCI Slot - 32 bits, 66 Mhz
* 2x PCI Slot - 32 bits, 33 Mhz
* mini PCI Slot - 32 bits, 33 Mhz (optional)
* RTC with backup battery
* ZigBee module (optional)
* UBoot 1.3.1
Preis für eine 667 Mhz cpu, ohne Ram 375,00 euro
SAM440ep-flex
