Aktuelle Zeit: 04 Aug 2026, 06:10
BeitragVerfasst: 28 Nov 2009, 16:33
ACube hat für das Sam440ep Board die U-Boot Version 1.3.1a veröffentlicht.
Dies sind die Änderungen:
Bassano del Grappa, 27 Nov 2009
ACube Systems is pleased to announce the release of a new version of U-Boot firmware for its line of motherboards Sam440ep and Sam440ep-flex.
This version addresses a number of problems and add some features and optimizations making it possible to cut down boot time by 3-12 seconds depending on the configuration of the board.
What's new in this version (for both versions):
* faster graphic card initialization, now it takes half the time than previous U-Boot version
* unified the first two countdowns, for an even faster boot
* solved compatibility issues with some Radeon 9200 and 9250 gfx cards
* reworked preference menu
Sam440ep miniITX version:
* a Radeon HD 2400 graphic card could be now used as secondary gfx card
"http://www.acube-systems.biz/download/S ... 091127.zip"
Sam440ep-flex version:
* added support for Silicon Motion 502 graphic card
* added experimental support for Catweasel MK4 controller
* a Radeon HD 2400 graphic card could be now used in both 33 and 66 Mhz PCI slots
Additional information:
Please note: UBoot and UBoot updater makes use of GPL code and thus are both published under GPL
. The sources can be downloaded from:
* "http://www.acube-systems.biz/index.php? ... ware&pid=1"
* "http://www.acube-systems.biz/index.php? ... ware&pid=2"
or, using a direct link, from:
* "http://www.acube-systems.biz/download/u ... rod.tar.gz"
ACube U-Boot V1.3.1a
BeitragVerfasst: 16 Apr 2010, 15:53
15 Apr 2010 23:20:00 GMT+1
U-Boot 1.3.1b for Sam440ep released
Bassano del Grappa, 15 April 2010
ACube Systems is pleased to announce a new release of the U-Boot firmware for its line of motherboards Sam440ep and Sam440ep-flex.
solved a graphic glitch when booting from SD card (or USB mass-storage device)
inverted ESC and SPACE actions at the boot countdown, now ESC brings to the U-Boot prompt and SPACE brings to the preference menu.
Please note: UBoot and UBoot updater makes use of GPL code and thus are both published under GPL.
BeitragVerfasst: 18 Apr 2011, 09:27
Fri, 15 Apr 2011
UBoot 2010.06-05 for Sam460ex available
Bassano del Grappa, Italy - 15, Apr 2011
ACube Systems is pleased to announce a new release of the U-Boot firmware for its line of motherboards Sam460ex.
What's new in this version:
* improved Radeon X1550, X1650, X1950 setup
* fixed a bug in the PCI-E setup which cures a crash when both a gfx card and an USB3 card were used
* DDR2 boost setup is now disabled by default, to enable it, set ddr2_boost to 1 from the U-Boot prompt
* removed a debug output from ext2fs.c
The updated installation guide describes in detail the usual installation method (ISO image) and alternative methods (TFTP). Inside the archive you will find both the ISO image and the TFTP updater
You can download installation archives from:
* http://www.acube-systems.biz/index.php? ... ware&pid=5
* http://www.acube-systems.biz/download/u ... rod.tar.gz
