Aktuelle Zeit: 30 Sep 2026, 07:35
 Betreff des Beitrags: RedEth V1.5 (08.03.2015)[OS4]
BeitragVerfasst: 20 Nov 2010, 17:07
20.11.2010 RedEth V1.0 [OS4]
Emilio Jimenez hat hier eine grafische Schnittstelle erstellt zum händeln von Verbindungen mit Samba.
Dies ist eine neugeschriebene und verbesserte Version von meinem ersten Skript (redethernet) erstellt mit Hollywood.
Schreibe mir deinen Kommentar über das Programm. Es kann für mich nützlich sein.
Ich hoffe, dass du es magst.
This is a rewritten and improved version of my first script (redethernet) made with Hollywood.
Make your comment about the program. It could be very useful for me.
I hope you like it.
 Betreff des Beitrags: RedEth V1.01 (22.11.2010)[OS4]
BeitragVerfasst: 23 Nov 2010, 18:37
22.11.2010 RedEth V1.01 [OS4]
In der Version 1.01 wurde der Fehler:
cannot read file t:sin !
file redethernet1.hws (current line: 28 - in function: Openfile)
von Emilio Jimenez behoben.
 Betreff des Beitrags: Re: RedEth V1.2 (23.10.2011)[OS4]
BeitragVerfasst: 01 Apr 2012, 16:50
23.10.2011 RedEth V1.2 [OS4]
Einige Bugs behoben und neue, verbesserte Dinge.
 Betreff des Beitrags: RedEth V1.3 (15.07.2013)[OS4]
BeitragVerfasst: 20 Jul 2013, 21:07
15.07.2013 RedEth V1.3 [OS4]
- Fixed bug in assignment letter font.
- Fixed access a drive that is not connected to the network, although defined in
preferences, and after connecting with another unit which is connected permitted
attempting to connect to the unit that is not connected, obviously unable to
really connect.
- Check the network availability. If not available, are finished running the program.
- Fixed bug where units connect two devices with the same name. Now it appears
the drive with the device to which it belongs as a name.
- Check if the network name actually corresponds to the selected device. If not,
automatically assigns the name of the device indicated the real, if it is not
already associated.
- Package of small bug fixes.
- Petitions distinct iconography system, distinguishing between warnings and
errors.
- Disabled the program output via "Ctrl-C" to avoid loss of configuration data.
- Block the introduction of blank name or the symbol "#" in the name of the
device and with a maximum of 30 characters long, to avoid network errors.
- Incorporated the following "tooltypes" HOTKEY, XPOS, YPOS, ICONIFY, AUTOMOUNT, AUTODISCONNECT
- Error Information. Control files required for full operation.
- Defined several variables to nil when not needed for memory usage optimization.
- Modified the composition of the icons belonging to General Options, remaining
Exit / AppIcon, Prefs, Help / Info. To access the icons double option is via the
left / right button of the mouse.
- Added link to the application SWAP, package samba, setting permissions, shared
drives, etc.. (Smbfs.conf). The connection is done through the browser that is
installed on the system, detects priority OWB, Netsurf, Timberwolf.
- Added the use of the right mouse button to mark that or those devices that
will be included in the automounter to start the program, if it is enabled in
the tooltypes.
 Betreff des Beitrags: RedEth V1.4 (26.10.2014)[OS4]
BeitragVerfasst: 22 Nov 2014, 14:53
26.10.2014 RedEth V1.4 [OS4]
- Fixed bug that caused error in identification of machine.
- Identification enabled to select a device, rather than in units, allowing us to locate units in protected computer.
- Fixed bug and enhanced in identifying and coding reminder of user and password.
- Small improvements of internal code and correction of minor errors.
- Fixed a bug in search of devices that enable the duplication of devices with different IP.
- In unknown devices also includes the MAC number for easy identification of equipment by the user.
- Modified the introduction of user and password; Now you can enter password without entering user and vice versa. Only both, at a time is entered when password is blank.
- Fixed errors internal data processing.
- Implemented detection and network printer configuration options through the user's Internet browser.
- Implemented file requester for printing it when you select a printer icon.
- Implemented drag and drop files on the printer icon for printing directly. Compatible only with postscript printers and pdf, postscript (#?.eps and #?.ps) and plain text file formats.
- When you start searching for units within a device can be canceled pressing the "Esc" key.
- Fixed graphical error at the moment of identification of units when its connected all together; in previous version the units are identified in green color when you move the mouse over every unit icon and not when
the global connection was made. Thanks to Joel Edberg's comments, has been corrected:
- Notification, in the installer, where is the program located at the end of the installation process.
- At start, searches for all available devices on the network.
- Added into tooltypes, BACKGROUND and COLORFONT to select respectively, the background image file and color of text you wish to use in the application. In case isnt activated this option, will be used by default the black color.
- Also improved all icons of application.
BeitragVerfasst: 08 Mär 2015, 17:58
08.03.2015 RedEth V1.5 [OS4]
Dies sind die Änderungen in V1.5:
- Angepasst an NAS-Festplatten oder Cloud-Typ-Netzwerke. Getestet mit WD MyCloud.
- Funktion implementiert, um vorhandene Geräte umzubenennen, Taste "DEL" ermöglicht die Funktion, um die Geräte auszuwählen, die umbenannt / deaktiviert werden sollen. Tipp implementiert auf Antrag Guillaume Bösel.
- Behoben: Fehler im Programm zum Zeitpunkt der Anforderung zum speichern in prefs beim beenden. Wenn Sie nichts auswählen, wird das beenden nicht erlaubt.
- Die Möglichkeit, Meldungen des Programms über das Ringhio Systems auszugeben.
Option in den Tooltypes des Programm-Icon auswählbar.
- Einige kleinere Grafikfehler in der Anwendung behoben.
- Jetzt wird überprüft ob das korrekte Samba installiert ist im System, wenn nicht läuft es nicht.
- Suchfunktion hinzugefügt, um mit einem rechtsklick auf das Symbol die Einheit hinzuzufügen.
- Optimierte Suche nach möglichen neuen Geräte über "verifizieren im Netz" .
- URLopen Nutzung hinzugefügt; Wenn in dem System installiert wird, anstatt verwendet werden
Standard-Browser von dem Programm verwendet.
- Neue Funktion in Prefs-Symbol. Jetzt, mit rechter Maustaste ermöglicht es uns,
zu entscheiden, ob wir die aktuellen Programmeinstellungen beseitigen wollen; es ermöglicht uns, alle Geräte neu zu konfigurieren.
- Behoben: Fehler beim Versuch, ein Gerät, wenn ein falscher Name oder null lesen
eingegeben wird.
- Zusätzliche Funktion der mittleren Maustaste; auf das gewünschte Gerät
ermöglicht Zugriff auf die Konfigurationsseite (nützlich für Router, NAS,
Netzwerkdrucker)
This are the changes in V1.5:
- Adapted to work with NAS hard drives or network cloud type. Tested with
WD MyCloud.
- Implemented the function to rename existing devices, by pressing the
'DEL' key enables / disables the feature to select the devices to rename.
Tip implemented at the request of Guillaume Boesel.
- Fixed bug in the program at the time of requesting for save in prefs on
exit. If you choose no, wont allow finish.
- Possibility to have notifications of the program in Ringhio system.
Option to choose into tooltypes of the program icon.
- Fixed some minor graphical errors in the application.
- Now, check if installed properly samba in the system; if not, you cant
run.
- Added search feature of one unit within a device by right-clicking on
the icon to add units.
- Optimized the search for posible new devices via Verify net.
- Added UrlOpen use; if installed in the system will be used instead of
default browser used by the program.
- New feature in Prefs icon. Now, with rigth mouse button allows us to
choose whether we want to eliminate the current program settings; will
allow us to reconfigure all devices and units.
- Fixed error when trying to read a device when an incorrect name or null
is entered.
- Added function to the middle mouse button; on ther desired device
allows Access to the configuration page (useful for routers, NAS,
network printers, )
