Aktuelle Zeit: 30 Sep 2026, 02:15
 Betreff des Beitrags: WinNet V0.3 (08.07.2012) [OS4]
BeitragVerfasst: 12 Mai 2012, 10:41
Postleitzahl: 70736
08.05.2012 WinNet V0.2 [OS4]
WinNet - Hollywood 5
AmigaOS 4 (ppc)
:daumen: Connect your AmigaOne500 with an ASPIREHOME Server
Important:
The software runs smooth with all features under OS4.1.
It's a simple GUI for an easy use of smbfs - based on SMBMounter.
Test Computer - AmigaOne500 and WinHomeServer ASPIREHOME.
The tool searches at first your WinHomeServer via Name then via IP.
Next it tries to connect your Amiga with the help of smbfs to your HomeServer.
Be sure to have smbfs on your amigaone500 - normally placed in SYS:c/.
To run the tool without getting to many errors edit first the WinNet.ini File.
Änderung zur Vorversion:
- disconnecting drawers now possible
- smbfs path in ini file
BeitragVerfasst: 11 Jul 2012, 21:00
08.07.2012 WinNet V0.3 [OS4]
Änderungen in dieser Version:
- little change in gui
- searching server optimized
- include some nice system sounds
- include more system alerter and info statusbar texts
- button to start system editor and edit winnet.ini
- button to activate new entries in winnet.ini after edit
- close all connections when closing WinNet
