Aktuelle Zeit: 14 Aug 2026, 18:07
 Betreff des Beitrags: iTunestoM3U V1.1 (16.06.2012)[OS4]
BeitragVerfasst: 01 Jul 2012, 13:33
15.05.2012 iTunestoM3U V1.0 [OS4]
Its a tool that basically goes through an iTunes Music Library XML file, converts the Location to an Amiga-style path and saves it in m3u format so you can playback anything from your music collection. You don't even need to copy the entire music library across to your Amiga, that's right with SMBFS installed and the music folder shared on the networked computer you can play your music across the network.
Now oggvorbis sound file is support.
Zum Thema im Englischen Forum/on topic to english forum
BeitragVerfasst: 01 Jul 2012, 13:34
16.06.2012 iTunestoM3U V1.1 [OS4]
Neu in dieser Version:
- You can now create separate playlists by Decade or by Artist.
