Aktuelle Zeit: 16 Dez 2025, 12:20
 Betreff des Beitrags: NSAddressbook V3.8 (03.03.2009)[OS4]
BeitragVerfasst: 15 Dez 2008, 10:44
PEB hat auch für den Browser NetSurf ein Adressbuch erstellt.
Die erste Version 1.0 lässt sich hier herrunterladen:
NSAddressbook V1.0
 Betreff des Beitrags: NSAddressbook V3.0 (30.11.2008)
BeitragVerfasst: 03 Mär 2009, 14:22
Neue Version 3.0 von NSAdressbook.
Änderungen sind:
*Added the ability to use links under group headings that can be expanded or contracted to reveal or hide the links.
*Added the ability to use 3 different kinds of arangements for the Quick Links (Horizontal, Vertical, or Custom).
*Added the ability to set the font style and size separately for the Links and Groups in the Address Book as well as the Titles and Subtitles in the Quick Links window.
*Added Reaction GUIs for changing the preferences for both the AddressBook and the QuickLinks (much thanks to Chris Young for his help with this).
*Added a separate program to make resizing and placement of the windows extremely easy.
*Removed the use of reqtools in favor of system string requesters (so now it is possible to copy and paste into the string requesters).
*Added a bunch of other features that were requested by H. Maier (Raziel).
*Added an AmigaGuide manual.
NSAdressbookV3.0
 Betreff des Beitrags: NSAddressbook V3.1 (05.12.2008)
BeitragVerfasst: 03 Mär 2009, 14:27
In der V3.1 von NSAdressbook ist diese Änderunge gemacht worden:
*Now the string requesters open on the correct screen if the screen is named
"OrigynWebBrowser".
NSAdressbook V3.1
BeitragVerfasst: 03 Mär 2009, 14:28
Version 3.2 mit dieser Änderung:
*Added support for the new "GETTITLE" ARexx command (used to auto-fill the title
for an added address).
NSAdressbook V3.2
BeitragVerfasst: 03 Mär 2009, 14:33
Eine weitere Version 3.5 von NSAdressbook wurde veröffentlicht in der diese Änderungen enthalten sind:
*Various bug fixes.
*Recently visited web pages are automatically stored, and can be revisited by clicking on their link buttons.
*The Address Book can also now be used to execute customized searches (like IBrowse).
NSAdressbook V3.5
 Betreff des Beitrags: NSAddressbook mit V3.6 (12.01.2009)
BeitragVerfasst: 03 Mär 2009, 14:35
In Version 3.6 hat sich dies zur Vorversion geändert:
*Merged the functions of the old "HistoryKeeper" (now removed) into the program "WinPrefs"---thus making the archive about 0.5 MB smaller, without loosing any functionality.
*Fixed a bug in the LookUp chooser.
*Added the option of having a thin border (no titlebar) for the Quick Links window---requested by H. Maier (Raziel).
NSAdressbook V3.6
 Betreff des Beitrags: NSAddressbook V3.7 (29.01.2009)
BeitragVerfasst: 03 Mär 2009, 14:38
Mit V3.7 gibt es diese Änderungen:
*Added the ability to have groups within groups, within groups, within groups, etc. ;-)
*Added "Hints" to the various buttons of the Address Book (configured through the Preferences)
*Fixed a problem that at least one person was having with OWBAddressBook and AISS.
NSAdressbook V3.7
BeitragVerfasst: 03 Mär 2009, 14:40
Die neuste Version von NSAdressbook enthält diese Änderungen:
*Increased the max number of address links from 100 to 250.
*Added support for mouse wheel scrolling.
*No longer uses the rx3h.library.
*Various internal optimizations.
NSAdressbook V3.8
