Aktuelle Zeit: 08 Dez 2025, 06:33
Ein neues Thema erstellen  Auf das Thema antworten  [ 57 Beiträge ]  Gehe zu Seite « 1 2 3 4 »
BeitragVerfasst: 11 Feb 2009, 13:42
Tach Uwe
Ich weiß das du es nicht böse meinst, aber für Besucher unserer Seiten würde das für mich so rüber kommen, als ob ausser dir hier keiner was an den Seiten macht.
Mein empfinden.
BeitragVerfasst: 11 Feb 2009, 13:57
Aber jetzt mal wieder zum Thema. :)
Es gibt eine neue Version 3.6 von OWB.
Und das sind die Neuerungen in dieser Version:
* Added support for using OWB local toolbar images instead of the global AISS ones and included an image set by Davide Calaminici. To use them move the files in "Resources/ToolbarImages/Davide Calaminici" to "Resources/ToolbarImages".
* Disabled support for tabs when running on AmigaOS 4.0.
* The progress bar is hidden again after loading the page has finished.
* Added the file chooser for uploads from the old Blastoise version.
* Instead of always creating new windows/tabs opening links in named frames works now.
* Disabled rendering in inactive tabs which aren't still loading.
* Fixed 4th/5th mouse button double back-/forward (bugs.os4depot.net issue #63).
* Changed copying images to the clipboard from 32 to 24 bit since too much old software doesn't work correctly with 32 bit pictures.
* No longer uses CLICKTAB_EvenSize, TRUE to make the tab labels as small as possible, it's using the GUI prefs settings for it now.
* The window was made too wide sometimes when opening new tabs, fixed.
* Changed "Copy as ISO-8859-1" menu item to copy texts in the local 8 bit charset instead of always ISO-8859-1.
* The menu and context menu texts use "Tab" instead of "Window" now when tabs are used.
* Redraw can be done with the F5 key as well now (bugs.os4depot.net issue #67).
* Session cookies are removed and the cookie file is only loaded and saved once now.
* Added scrollbar theme from the shellos branch of OWB.
OWB V3.6
BeitragVerfasst: 24 Feb 2009, 23:48
Und wieder gibt es eine neue Version von OWB.
Änderungen in V3.7 (24.2.2009) sind:
- Updated to SVN revision 842 (OWB milestone Galegon).
- Fixed bugs.os4depot.net issues #67 (F5 is reload instead of redraw now), #69 (restore active tab on uniconify), #70 (mouse button events outside of the webview didn't work), #73 (about: url support), #84, #85 (added home and end key support) and #90 (tab titles with underscores work correctly now).
- Added new keyboard shortcuts:
<alt><left>/<right> = back/forward (only if no text input is active).
<lamiga><d> = activate url gadget
<lamiga><k> = activate search gadget
- Alt texts of images are displayed in the tooltips as well now.
- Added "Save As..." menu item.
OWB V3.7
BeitragVerfasst: 25 Feb 2009, 06:37
wie würd der Ami sagen?
"awesome"
ist echt wahnsinn wie der Jörg sich da reinhängt, respekt. Mal im Laufe des Tages saugen und antesten :mrgreen:
 Betreff des Beitrags: OWB V3.8 (27.03.2009)
BeitragVerfasst: 29 Mär 2009, 10:36
In der neusten Version 3.8 von OWB sind diese Änderungen enthalten:
-Fixed ARexx GETTITLE returning frame names instead of the titles.
-When loading a page fails OWB displays an error message now.
-Added support for file:// URLs with AmigaOS paths and using a file name as argument when starting OWB from shell.
-Fixed double and trippe clicks.
-Fixed bugs.os4depot.net issues #93 and #101 (bookmark crashed on iconify if OWB is running on an owb screen).
-Updated to SVN revision 885.
-Removed AmigaOS 4.x cookie workarounds since OWB has support for persistent cookies again. Removed COOKIES tooltype and added COOKIEDB instead.
-Disabled a wrong cookie security check, for example GMail works now.
-Implemented downloads.
-Now uses an extended string gadget with history created by Rene W. Olsen and Stephen Fellner for the URLs.
-Added about: page created by Samir Hawamdeh.
OWB V3.8
 Betreff des Beitrags: OWB V3.9
BeitragVerfasst: 14 Apr 2009, 10:04
In der neuen Version 3.9 würde dies geändert:
* Updated StringView, should work when using OWB on an own screen now.
* Added an error requester to StringView if expat.library can't be opened.
* Reverted the 3.7 cookie changes as they broke more than they fixed, it's tooltype COOKIES and a plain text file instead of the database again.
* Fixed iconify bugs when using tabs.
OWB V3.9
 Betreff des Beitrags: OWB V3.10
BeitragVerfasst: 14 Apr 2009, 10:06
Und wieder hat Jörg eine neue Version von OWB herraus gebracht, in der folgende Änderungen enthalten sind:
* Fixed bugs.os4depot.net issues #70, #97, #103, #112, #116, #118 and #127.
* Fixed http://crashlog.os4depot.net/cl166
* Updated to SVN revision 912.
* Reimplemented downloads based on the new OWB implementation.
* Fixed a bug in the StringView *Zensiert* function for complete URLs.
* Implemented support for font family lists and aliases (Courier <> Courier New, Times <> Times New Roman and Helvetica <> Arial).
OWB V3.10
 Betreff des Beitrags: OWB V3.11
BeitragVerfasst: 19 Apr 2009, 23:41
Und mit V3.11 ist schon wieder eine neue Version veröffentlicht, in der Jörg diese Änderungen gemacht hat:
-Updated to SVN revision 915.
-Fixed bugs.os4depot.net issues #120 and #129.
-Updated about: contents.
-Improved font selection if the webcore fonts are not installed.
-Changed rendering method reducing the CPU usage if there are several changes, for example GIF anims, done at the same time, and when entering texts.
-Included new icons, toolbar and scrollbar images and scripts from Martin Merz.
OWB V3.11
 Betreff des Beitrags: OWB V3.12
BeitragVerfasst: 25 Apr 2009, 16:21
In der neue Version 3.12 von OWB sind diese Änderungen enthalten:
* Fixed bugs.os4depot.net issues #134, #135, #136, #139 and #140.
* Fixed http://crashlog.os4depot.net/cl173 cl175, cl176, cl177, cl178, cl179 and cl181.
* Updated curl-ca-bundle.crt.
* Updated to SVN revision 920.
* Fixed clicktab problems.
OWB V3.12
BeitragVerfasst: 27 Apr 2009, 12:56
bin gerade mit der 3.12 von OWB hier, der Browser wird immer besser :top:
Eigentlich fehlen jetzt nur noch 2 Dinge ein integrierter Downloadmanager mit Fortschrittsanzeige und ein Passwortmanager, dann würde ich IB so langsam aber sicher seltener :D benutzen
BeitragVerfasst: 27 Apr 2009, 19:35
Seit OWB das mit den Downloads hin bekommt, benutze ich IB nur noch für die Kontrolle, wenn ich was für die Webseiten gemacht habe. 8)
BeitragVerfasst: 09 Jun 2009, 08:10
OWB 3.14 ist draussen.
Nun kann man in den Tooltypes auch den Downloadpfad definieren. :daumen3:
Super arbeit Jörg, dankeschön :D
BeitragVerfasst: 09 Jun 2009, 19:10
Klasse und was Jörg da noch alles geändert hat:
* Fixed progress bar. Since the changes need new methods the text search is now disabled on AmigaOS 4.0.
* Fixed several cookie bugs, for example GMail and the URL from bugs.os4depot.net issue #131 are working now.
* Added more checks for broken font installations.
* Implemented HTTP authentication, partially based on the AROS OWB diffs with minor bug fixes, and added support for http://username:password@example.com/ urls (bugs.os4depot.net issues #121 and #149).
* Added support for scrolling with space and backspace (bugs.os4depot.net issue #169) and <shift><cursor up/down> (#186).
* Added ToolType DOWNLOADDIR (bugs.os4depot.net issue #154).
* Added ToolType DISABLEGIFANIMS.
* Fixed bugs.os4depot.net issues #170, #175, #180, #183 and #185.
* Added Accept-Language: header based on locale preferences.
* URL and web search gadgets did not always work if they weren't activated with the mouse, fixed.
* Updated to SVN revision 994 (OWB milestone Galeking).
* Changed <RAmiga><C> menu shortcut from "Copy" (UTF-8) to "Copy as {8 bit locale charset}" (bugs.os4depot.net issue #176).
* Added support for closing the current window/tab with <ESC> (bugs.os4depot.net issue #187).
* Updated SplashLauncher to version 1.3 (bugs.os4depot.net issue #117).
* Added new toolbar images and updated scripts from Martin Merz.
OWB V3.14
BeitragVerfasst: 19 Jun 2009, 21:31
Und wieder hat Jörg Strohmayer eine neue OWB Version veröffentlicht, in der diese Änderungen enthalten sind:
* Fixed a rendering bug (bugs.os4depot.net issues #198 and #200).
* Fixed bugs.os4depot.net issues #202, #203, #210 and #212.
* Updated to SVN revision 1006.
* Added some workarounds to prevent wrong redirection to WAP versions on broken sites like like http://www.microsoft.com/ and http://www.kauppalehti.fi/ (bugs.os4depot.net issue #213).
* No longer uncompresses when downloading, for example gzipped tar archives.
OWB V3.15
BeitragVerfasst: 17 Okt 2009, 22:46
Die neue Version von OWB hat folgende Änderungen:
3.16 (17.10.2009)
* Updated to SVN revision 1094 (OWB milestone Pukapuka).
* Removed AmigaOS 4.x cookie workarounds and replaced COOKIES tooltype by COOKIEDB. If you still have a cookieCollection.db file from OWB version 3.8 you should delete it.
* Fixed bugs.os4depot.net issues #57, #60, #96, #132, #184, #223, #227, #244, #248, #250 and #259.
* Implemented creating pointers from images.
* Implemented favicon support.
OWB V3.16
