Aktuelle Zeit: 07 Sep 2025, 22:35
 Betreff des Beitrags: CollageMaker V3.0 (02.03.2011)[OS4]
BeitragVerfasst: 19 Mai 2009, 10:56
18.05.2009 CollageMaker V1.0 [OS4]
PEB hat wieder ein neues Programm mit Hollywood erstellt, es ist Collagemaker.
"Collage Maker" is another one of my 'bloated' programs made with Hollywood
4.0---I hope you enjoy it!
The idea of this program is to make it easy to combine multiple picture (up to
20) into one picture (a collage) that can then be printed in such common sizes
as 4x6, 5x7, 8x10, and 11x14---though since it is always in landscape, the
dimensions are more accurately listed as 6x4, 7x5, 10x8, 14x11.
There are many options available for picture layout and grid options---including
the use of patterns that can be tinted with color, and special options like fade
and shadow effects. The best thing to do is to experiment with the buttons and
learn what can be done that way.
Note: When using Zoom, clicking the left mouse button over a picture will zoom
further into that picture; however, holding down the SHIFT key while clicking
the mouse button will cause the picture to zoom out instead.
For saving your collage, there are two options: 1) You can simply save the
collage *picture*, which can then be printed; or 2) You can save the collage
*project*, which allows you to come back and adjust any aspect of your collage
at a later time.
Depending on how many pictures you use in your collage (and depending on how
high of resolution those pictures are), you may not have enough system
memory---Collage Maker does not make use of virtual memory. If you need it,
there is a Low Memory option that can be turned on or off through the "Prefs"
text file. Setting LowMem=1 will use much less memory, but it will also slow
down certain aspects of Collage Maker. (Setting it to LowMem=0 will turn off the
Low Memory option.)
Special thanks to:
*Mason for his AISS artwork and Icons.
Version 1.0 (5/18/09):
*First attempt.
Einstellung - Dimension 4x6
Einstellung - Dimension 11x14
Funktion - Add Pic
Funktion - Remove Pic
Funktion - Change Template
Funktion - Move Pic
Funktion - Zoom Pic
Funktion - Grid Option
Funktion - Grid Option (Große Darstellung)
Funktion - Elliptish Mask
BeitragVerfasst: 19 Mai 2009, 20:24
Hast Du das Programm schon getestet?
BeitragVerfasst: 20 Mai 2009, 15:33
Salli Tipsi
Nein, bin ich noch nicht zu gekommen, hatte das nur beim durchstöbern vom OS4Depot entdeckt und hier direkt eingetragen.
Schau aber das ich das bald mache, weils mich ja auch interessiert, was PEB da wieder schönes gemacht hat.
Mach auch wieder ein paar Screenshots die ich dann hochlade :wink: .
BeitragVerfasst: 20 Mai 2009, 23:34
Habs grad mal getestet und oben die Screenshot mit dazu getragen. :wink:
Mein Eindruck:
Wieder ein prima Programm das PEB da mit Hollywood erstellt hat.
Sicherlich nicht für jeden zu gebrauchen, aber es zeigt, was es mit Hollywood für Möglichkeiten gibt, kleine Programme zu erstellen.
Ich wäre schon froh, wenn ich verstehen würde, wie man sowas macht.
BeitragVerfasst: 23 Mai 2009, 14:58
Vielen Dank für die Screenshots. Sieht gut aus
und wieder mal ein Beispiel dafür, dass Hollywood
nicht nur für Präsentationen geeignet ist.
 Betreff des Beitrags: CollageMaker V2.0 (06.04.2010)[OS4]
BeitragVerfasst: 14 Apr 2010, 02:58
07.04.2010 CollageMaker V2.0 [OS4]
Version 2.0 (4/7/10) mit diesen Änderungen:
*Redesigned the GUI.
*Now pictures can be added or replaced using "Drag & Drop."
*Added the ability to drag the borders of individual cells to increase or decrease their thickness.
*Custom text can now be added to the collages (right-clicking the text blocks shows options).
*PNG images with alpha-channel transparencies can now be used and the grid border will be seen through the transparent areas.
*Another "mask" (in addition to the ellipse) option has been added---"sub-border" (an inner border around a specific picture cell).
*Placement "crosshairs" have been added when moving pictures with the "Hand" tool.
*Many old functions have been made faster.
BeitragVerfasst: 25 Apr 2010, 22:21
Hab hier mal die Links wieder korrigiert, damit auch die Bilder wieder dargestellt werden. :wink:
 Betreff des Beitrags: CollageMaker V2.1 (30.08.2010)[OS4]
BeitragVerfasst: 30 Aug 2010, 13:36
30.08.2010 CollageMaker V2.1 [OS4]
PEB hat auch an CollageMaker nochmal Hand angelegt und dies geändert.
Version 2.1 (8/30/10):
*Fixed some bugs that showed up with AISS 4.10.
BeitragVerfasst: 03 Mär 2011, 11:23
02.03.2011 CollageMaker V3.0 [OS4]
Neue Version CollageMaker mit diesen Änderungen von PEB:
Version 3.0 (3/2/11):
- Two new kinds of collages (in addition to the standard grid collage) are now possible to create:
1) Special Templates are ones that combine a specific number of pictures into a collage design that cannot be achieved using normal grid lines.
There are only a few currently built into Collage Maker.
If you have a design that you would like to see added, send me an e-mail with a sample.
2) Freestyle collages are ones where the placement, size, rotation, and borders of the picture cells can all be freely changed.
When the Freestyle button is pressed, the pictures will first arrange themselves in an orderly way according to the last active template; but they can then be dragged anywhere and further configured by Right-clicking on them.
- Top graphics with alpha-channel transparencies can be added.
- Outside borders can be added around the picture cells.
- Collage projects can now use multiple pages of different formats.
- Built-in help and reference guide.
