Aktuelle Zeit: 16 Jun 2026, 22:43
 Betreff des Beitrags: Jack V3.1.3 (23.04.2012)[OS4]
BeitragVerfasst: 01 Jul 2012, 11:52
23.04.2012 Jack V3.1.3 [OS4]
Änderungen seit 3.1.2
* Jack no longer requires an Internet connection to startup. Instead dialog
boxes will appear over relevant icons and buttons to inform user of functions
that are inaccessible.
* Whenever Jack needs to access a remote resource it will now always check an
internet connection is available first before attempting anything else.
* Connections: All data connections have been tidied up and consolidated where
possible. HTTP error handling has now been implemented for handling 404 errors
and lost in connection will be picked up. HTTP Resume has not been looked at
this stage.
* Renamed and expanded the Audio and Music bundle to include the Video player-
Mui-Mplayer.
* Entering a http:// address in the File Manager path will now check for OpenURL
and use that instead of defaulting to Jack's backup URL handler.
* Slideshow: Fixed position of Reflections.
* Slideshow: Fixed traversing Volumes/Drawers.
* Slideshow: Fixed errors in loading images without an Alpha-channel.
Zum Thema im Englischen Forum/on topic to english forum
 Betreff des Beitrags: Jack V3.2.1 (07.05.2012)[OS4]
BeitragVerfasst: 01 Jul 2012, 11:53
07.05.2012 Jack V3.2.1 [OS4]
Änderungen seit 3.2 (08.95.2012)
* Video End: After a video ends the mouse pointer was remaining hidden.
* Gtmooya: Removed rogue debug output.
* App-Store: Fixed download path for non-Push4Dock users - fixes double-RAM:
assignment.
Änderungen seit 3.1.3
* WarpOS compile now available on Aminet.
* (MorphOS Only) Debug output removed.
* Check for New Updates (of Jack) has been removed for all non-AmigaOS4
operating systems.
* JackTunes restricted to AmigaOS 4 for the time being due to its reliance on
Python and SMBFS.
* AppStore: All downloads (apart from Featured Downloads) are now asynchronous.
In plain english this means multple downloads are now possible, even if you
close the Appstore window and move into any other part of Jack the download(s)
will continue in the backgrond. (AmigaOS 4 Only) Outside of the Appstore you
will be notified by the Ringhio notification system that a download has been
completed and is available to install as normal through the Download Manager.
* The state of the download list is updated as each download finishes, if you
end up with a partial download (computer crash/lost connection) during
downloading - on restarting Jack- you will be given the opportunity to either
re-download the partial download(s) or remove them from the list.
Notice I said 'the list is updated as each download finishes' - if you only
downloaded 1 item you will not necessarily be given this same opportunity.
* It is currently not possible to quit Jack if downloads are in progress or
partial downloads exist in the Download Manager. Please visit the download
manager and rectify. Might newbie-fy this behaviour in the future.
* (AmigaOS 4 Only) Every 4 hours news from Amigaworld is shown as a ringhio
notification assuming your rexx server is running; I know some weird Amiga users
love to turn stuff off unnecessarily!
* Apologies for delay, fixed the malformed url string for adding events to
Google Calendar. Days and months are now zero-padded correctly.
* (MorphOS Only) All PDF calls are pre-configured to Apdf on the system
partition inside the Applications drawer.
* The filesize is more correctly positioned underneath each download that is in
progress.
* Fixed possible inaccessiblity of the 'Install Now' option in the Download
Manager.
* Added Jack Icon to the Ringhio notification messages
* Jack now has an Arexx port. A small number of initial arexx messages have
been added. See Jack_Arexx_Commands.rexx included for the current list. This
will be much improved in a future release foreinstance being able to process
images and applying Image Effects and Watermarks.
* Removed redundant locale strings
* (Other OS) Corrections in AmigaOS Knowledge base with regard to local files
and helper applications.
* (AmigaOS 4 Only) During installation the user will now be asked whether they
wish to add Jack to the Dock (rather than auto-detection/auto-placement) and
they will be asked whether they want Jack to be added to WBStartup
(recommended).
Sidenote to developers/how to do: WBStartupCTRL ADD <path>/<filename> >nil:
 Betreff des Beitrags: Jack V3.2.2 (09.05.2012)[OS4]
BeitragVerfasst: 01 Jul 2012, 11:56
09.05.2012 Jack V3.2.2 [OS4]
Änderungen seit 3.2.1
* Fixed mouse pointer not changing state.
 Betreff des Beitrags: Jack V3.2.3 (07.08.2012)[OS4]
BeitragVerfasst: 14 Aug 2012, 13:18
07.08.2012 Jack V3.2.3 [OS4]
* Music player: A lot of work has been done on the music player, but there are still a number of jobs outstanding that I am fully aware of. However feel free to have a play. Ps. Local playback hasn't been started yet.
* Alarms: The Alarms were not being freed from memory on sample end this blocked other Hollywood applications running from reaching AHI, fixed in configuration window as well.
* Colour Commodity Window: It is now possible to customise the Text Colours of most information shown in the main Commodity window. Simply right-click on any text to change the colour - a Color Wheel will open - pick a colour and the text is instantly changed. Changes are automatically saved.
* M is a Global Key to Mute any Music that may be playing.
* Changed keyboard shortcut from 'm' to 't' in Image Save window.
* Changed keyboard shortcut from 'm' to 't' in File Search window.
* Caps Lock position is no longer relevant for shortcut keys, some keys where case sensitive in various windows of the application.
* Commodity Window: It is no longer possible to use LEFT/RIGHT arrows to switch through months when the weather is being viewed, the forecast stays in view.
 Betreff des Beitrags: Jack V3.2.4 (12.09.2012)[OS4]
BeitragVerfasst: 27 Okt 2012, 16:36
12.09.2012 Jack V3.2.4 [OS4]
Änderungen seit Version 3.2.3
* Local playback functionality (of an iTunes Library) in JackTunes is now
working, however, there are a still a number of known bugs and features yet to
implement. Please feel free to have a play around.
* Improved AmigaOS Version detection (Community Stats/Get Info)
* AmigaOne 500 is now identified under CPU detection (Community Stats/Get Info)
* Improved identication of SAM 440 EP and Pegasos
* Colour Commodity changes caused Jack problems with running from the command
line, now fixed.
* JackTunes: Notification messages are now sent to Ringhio as a new song starts
- but only when music interface is closed.
* JackTunes: Returning into the interface will always show the correct Artist
and Title for the currently selected track.
* JackTunes: Configuration window will now dismiss on selecting Later/Cancel.
* JackTunes: Mini Window now includes Title and Artist text.
* AppStore: Small advert area with links to my company Lake Marketing and Events
( www.lakemarketingandevents.co.uk )
 Betreff des Beitrags: Jack V3.2.5 (27.09.2012)[OS4]
BeitragVerfasst: 27 Okt 2012, 16:38
27.09.2012 Jack V3.2.5 [OS4]
Änderungen seit Version 3.2.4
* AmigaOS 4.1 Update 5's introduction of asynchronously loading the TCP/IP at
Workbench startup exposed a new bug in Jack. The DELAY tooltype was previously
being ignored, this has now been fixed. If you still see an error message if
starting Jack this way simply increase the value of the DELAY tooltype. Value
is no. of seconds.
* Python ITC Extractor has been updated to version 0.3.2 which adds support for
Apple's use of ARGB images in album cover artwork.
Thanks to Simon Kennedy. http://www.sffjunkie.co.uk/python-itc.html
* Moved php scripts to another server, older versions of Jack will continue to
run for a limited time only.
 Betreff des Beitrags: Jack V4.0.2 (25.05.2013)[OS4]
BeitragVerfasst: 01 Jun 2013, 14:46
25.05.2013 Jack V4.0.2 [OS4]
Änderungen seit 4.0.1
* Save button in the Configuration Window was broken, fixed.
* AppIcon images relating to the 'Application' tab in the dashboard are now
saved to disk resulting in quicker load times.
* The 'applaunchicon' error reported by 328gts and a few other users should now
be fixed, however unable to test so don't quote me on it.
* NEW: A small but useful VAT Calculator has been added into the dashboard.
* Some left-over debug messages removed from the AppStore.
17.05.2013 Jack V4.0.1 [OS4]
Änderungen seit 4.0
* Push4Dock no longer required, instead Push4Dock file structure is enforced.
* As part of the above change, Downloads are now installed into the
'Application Files' drawer.
17.05.2013 Jack V4.0 [OS4]
Änderungen seit 3.2.6
* Removed the button that returned the calendar to the current month as it was
a little unnecessary and was broken anyway.
* Added string focus (also known as activeobject) into several windows, this
works well with the 'advanceoncr' property to increase userability and removes
unnecessarily clicks and keboard tabulation on several interfaces.
* Removed OpenURL from MorphOS distribution as apparently it is not required
because it comes with MorphOS as standard. Reported by Tom01 via Jack website.
Thank you.
* Added TIFF Plug-in into the installation and distribution of Jack.
* Now requires mcc_thebar available at:
http://www.os4depot.net/share/library/m ... thebar.lha
MCCBar has no support for WarpOS and Amiga Classic removed completely because
Jack is geared towards computers with faster CPUs and to be honest it is going
to be pig slow on anything than a PowerPC processor or AROS.
* Now will handle 'stuck' downloads correctly on starting Jack by moving them
from the list/disk if found without inteferring with other partial downloads
that maybe on the list.
* New Applications tabbed into the new dashboard. This will allow you to launch
any application and other features including revealing them on the Workbench
and adding comments. Comes complete with search engine and the ability to add
new applications to the list. Applications are retrieved via the AmigaOS AppDir
system. Thus AmigaOS4 is mandatory for this page tab to enabled. FYI Jack will
attempt to make the Application's filename more meaningful, converting '-' and
'_' where necessary. It will also uppercase known acronyms. The same routine
is used throughout the AppStore as well.
* AppStore: If an archive filename contained both '-' and '_' only '-' was
being replaced and displayed to the user. Fixed.
* After capturing the screen the file manager window no longer opens, removed
because after a while I found it quite annoying.
* In the Calendar window the Previous and Next months correctly disable and
re-enable when switching between Calendar and Weather displays now. The right-
mouse clicks for colouring the interface also correct disable/enable between
displays.
* Drag 'n' Drop has been removed in favour of using the 'Action' button in the
file manager.
* All MacOS/Win32/Linux support code I had been introducing over recent updates
has been now been removed since Jack has been refactored to use MUI extensively.
* Arexx support has been improved further with the introduction of App-Store
specific Arexx Commands. Any Amiga Application can now Download, Query or even
Install applications from the Jack AppStore and even check what versions of
software the user has downloaded and if a newer version is available Download
and Install that too. Of course Jack has no real way of checking whether
certain downloads have indeed been installed correctly (or at all) so
foreinstance with a Library you will still need to carry out your own sanity
checks. This feature is only as good as the developers that choose to use it
and the quality of installation scripts that have been written for existing or
future software. Please use it!
* Removed internal calculator in support of the native application.
* During first time install, users who are found not to have Push4Dock installed
will be asked to specify a Download Path for the AppStore. This is a mandatory
requirement of running Jack. It is not possible to set a download path to a
common system Drawer such as. C:, DEVS, L:, Libs: etc... nor is it possible to
select the RAM: or RAM Disk. Circumvention is discouraged. I do want any users
to save any downloads to any volatile destination.
* Removed caching from the App-Store, I believe MySQL can quite easily handle
the number of current data requests from my online database for the foreseeable.
* Global AmigaOS environmental variables are now set matching some of those
specified by the user in configuration window. Foreinstance $JDOWNLOAD contents
the path to the users download drawer. This can be useful for developers when
writing future scripts and compliments the new Arexx AppStore interface.
The following variables are available: JCLOCK - whether the user prefers a
12 or 24 hour clock, JDOWNLOAD - the user's AppStore Download Path, JICONHELPER
= specified tool that opens Icon Files, JLOCATION = the user's (weather)
location, JPDFHELPER = specified tool that opens PDFs, JTEMP = whether the user
prefers temperatures displayed in (C)elsius or (F)ahrenheit and JTXTHELPER =
specified tool that opens Text-based files.
* Jack is no longer a File Requester replacement, it can no longer be started
from the Shell nor does it accept any arguments.
* With the change to MUI window it is now only possible to Mute any playing
music from non-MUI windows, i.e. the Calendar Window.
* Slideshow Mode - It is now possible to turn the Reflections off to improve
system performance. The option is available in the main Configuration window.
* Configuration: The Download Path is now checked to find out whether it exists
or not, if its doesn't the configuration cannot be saved through the interface.
* Configuration: Stupidity checks added to all fields on Saving. Foreinstance if
a Helper application doesn't exist fields and configuration return to defaults.
Similar with the Downloads Path, if it doesn't exist or is left empty this will
default to RAM.
* Configuration: Warning message added when Saving the configuration if apps
have already been downloaded and the user attempts to change the Download path.
* App-Store: Resuming of partial downloads on an unexpected quit of Jack has
always been working unknown to the user - however now the user is now told that
this is happening. A notification message will be sent to Ringhio on starting
Jack when this happens.
* Screen Capture: On saving capture, you are now told where the image has been
saved.
* App-Store Donations: Now only available to users who have signed-up/into the
AppStore.
* App-Store: Download options are available throughout the Store not just on
the Download tab. Foreinstance it is possible to Rate a download from the
Search results or the Recent List.
* Featured Software: Downloads are now asynchronous.
* App-Store Donations: Fixed the problem regarding the currency code.
Donations are now set against the developer's own currency code preference.
* Sharing links in the App-Store, the URLS are now correctly converted into
lower case INCLUDING the category, i.e. links are now correct when sharing to
Facebook, Twitter (new) and Clipboard.
* Entire Recent list is now shown in the App-Store, not just the top 12 uploads
* For those users who love to tinker, the Bookmarks in the App-Store can be
configured manually via gui.xml, however make sure the columns are balanced - in
other words the number of bookmarks must be an Even number.
* Searching the App-Store is no longer case sensitive (!)
* It is now possible to turn ON and OFF the Reflections in the Slideshow mode
* Enhancements to the Information Window in the File Manager
* Date of the month is now sent to the Google - Add an Event function correctly
* Introduced handling of ENVARC:, ENV:, RAM: and T: devices for non-AmigaOS like
operating systens.
* Fixed cross hair pointer not appearing in Color Wheel window.
* GetPixel: The missing font error has been fixed. You can now press 'G' again
from the Commodity Window to open obtain the Hex value of any colour on the
screen.
* Animated GIFS: It is now possible to drag and drop animated GIFs on to Jack,
all frames are played in a continuous loop.
* Screen Promotion: You can now press P to promote Jack to another public
screen. Please note unfortunately it is not yet possible to perform a screen
grab of any public screen aside from the Workbench. *AmigaOS and compatibles
only.
 Betreff des Beitrags: Jack V4.0.3 (17.06.2013)[OS4]
BeitragVerfasst: 23 Jun 2013, 23:00
17.06.2013 Jack V4.0.3 [OS4]
Änderungen seit 4.0.2
* Change Password, closed potential security breach. Fields are now emptied
on re-opening the window.
* Change Password button, broken, now fixed.
* Sign-up button, corrected keyboard shortcut.
* Closed another potential security breach, instead of an Email Reminder the
user opts to Reset their password. A new random password is sent instead.
* Added more sanity-check within the JackTunes configuration window and with
the actual loading/copying of the iTunes Library file from a remote or local
source.
* Removed the 'Mount JackTunes' script and icon from the distribution as they
are no longer required.
* Updated skins, made interface a little more transparent and a three new
buttons.
* The new buttons all the user to change the global volume level of AmigaOS.
Mixer is required in order to allow this functionality otherwise the buttons do
nothing.
 Betreff des Beitrags: Jack V4.0.4 (25.06.2013)[OS4]
BeitragVerfasst: 03 Jul 2013, 22:46
25.06.2013 Jack V4.0.4 [OS4]
Änderungen seit 4.0.3
* Added check for TheBar.mcc and TheBar.mcp. Jack will not start without them
and will inform the user where to download.
* Updated AISS version check string to 4.12
* Reflection cycle gadget saving state now fixed
* iTunes Player is only available to me, the developer whilst I resolve existing
bugs, which is why it is currently disabled in this version.
* Volume names with an ampersand in them are currently excluded from the
'Open Volumes' menu option attached to the Dashboard window.
 Betreff des Beitrags: Jack V4.0.5 (28.06.2013)[OS4]
BeitragVerfasst: 03 Jul 2013, 22:48
28.06.2013 Jack V4.0.5 [OS4]
Änderungen seit 4.0.4:
* Default location for a first-time run of Jack is now top-right as per previous versions - not top left!
* Configuration Window: Now possible to save position of the Calendar/Weather window, corrections to X and Y fields in moving the Window after entry.
* Configuration Window: Cancel button will also move back the Window to its previously saved position.
* Fixed a myriad of image/icon and text field issues in the AppStore.
 Betreff des Beitrags: Jack V4.0.6 (15.07.2013)[OS4]
BeitragVerfasst: 20 Jul 2013, 21:15
15.07.2013 Jack V4.0.6 [OS4]
Änderungen seit Version 4.0.5:
* The Add button inside the Application Switcher has been fixed and more sanity
checking has been added.
* A 'Remove' button has added inside the Application Switcher which allows the
user to remove an application from the list. It is not possible to remove an
application that resides on the system partition. You are not one of those
users who store non-AmigaOS software of the system partition are you?
* Application Switcher is now first populated when the corresponding tab is now
selected for the first time rather than every time Jack is launched.
* Thanks to Hollywood 5.3 there is no longer a cap on URL length which now means
that all 'Star Data' is shown completely from top to bottom regardless of how
many items are present in the listview. This is instantly noticeable on the
'Store' tab where in prior versions of Jack I had no choice but to introduce an
artificial cap to avoid an unwanted DSI.
* Screen promotion of Jack should now be restricted to 24 bit screens only,
hard to test was unable to work out how to create a screen with less bits.
* Added information about which Hollywood version Jack was compiled in.
* Removed Check for Update button/menu items. Future updates will now be
delivered by AmiUpdate.
* As requested AmigaOS on Google+ has now been added into the Popular Bookmarks.
* AppStore Downloads Tab: When selecting to 'Show in Drawer' a check is now
made to find out whether the archive has since been deleted and if so give the
user the opportunity to remove it from the list.
 Betreff des Beitrags: Jack V4.0.7 (05.08.2013)[OS4]
BeitragVerfasst: 06 Aug 2013, 19:51
05.08.2013 Jack V4.0.7 [OS4]
Änderung seit Version 4.0.6
* MACE added to Entwickler-X Games tab
* It is now possible to type more symbols and importantly a 'space' in the
Search field within the AppStore, please note the results will returning matches
containing the entire string; no 'OR' logic is taking place.
* Added new Bundle to AppStore - the QT Bundle - I am sure this will grow over
time as the number of QT ports continues to grow.
* Renamed Office Bundle to AmiCygnix Bundle.
* Removed AmiCygnix Base from AmiCygnix Bundle, advised user to download
separately.
* Updated AmiCygnix Bundle and Entertainment Bundle with new downloads.
* Fixed some display bugs in the hastily written VAT Calculator, still not
perfect padding to two decimal places, but much better than before.
* Application Switcher population is now exclusive to selecting the associated
page tab as originally intended.
* A few layout refinements of the dashboard.
 Betreff des Beitrags: Jack V4.0.9 (22.09.2013)[OS4]
BeitragVerfasst: 28 Sep 2013, 19:29
22.09.2013 Jack V4.0.9 [OS4]
Änderungen in Version 4.0.9
* Fixed missing arrow left and right for traversing through the months of the
year.
* QT Bundle updated with a succession of new contributions, personally approved
by myself with a few reservations on some of these. ClipGrab is a personal
favourite right now.
* Removed JackTunes due to limitations that still exist between Arexx, AmigaOS
and Audio playback via AHI. JackTunes will reappear as a separate application
with no Arexx port.
* Reset button in Config Window: Small correction on how default path to Home
Directory is determined.
* Removed some guy called Fred from the Twitter search filter
Änderung in Version 4.0.8
* Fixed missing brush error on Weather Refresh button, reported by samo79, thank
you.
 Betreff des Beitrags: Jack V4.1 (28.11.2013)[OS4]
BeitragVerfasst: 30 Dez 2013, 22:47
28.11.2013 Jack V4.1 [OS4]
Änderungen in V4.1:
* Search: Fixed Rename / Delete / Add Comment, no more [5345dfsd35] errors.
* Search: Export button icon changed to something less incorrect!
* Search: Matches in APPDIR: are now excluded.
* AppStore: A new page has been added into the Information window that allows
the user to read user reviews/comments. In addition a user who has signed up to
the AppStore can also add their own review or comment to the AppStore.
* AppStore: If the Information window is open, selecting an App on the Store,
will update the text in the information window accordingly.
* AppStore: Identified an mui.DoMethod error/loophole relating to the Bundle
page that I was able to jump through as a result of the above change. Loophole
closed.
* DashBoard: Somehow APPDIR: found itself listed in the menu Jack->Volumes.
* Dashboard: The Push4Dock default paths mentioned in the menu Jack->Volumes
were not set correctly.
 Betreff des Beitrags: Jack V4.2 (02.12.2013)[OS4]
BeitragVerfasst: 30 Dez 2013, 22:49
02.12.2013 Jack V4.2 [OS4]
In V4.2 wurden diese Änderungen gemacht:
* Community Stats: Re-organised the GUI and added icons into table rows to make
the layout look more attractive.
* AppStore Store Tab: Saved User Comments/Reviews were being retrieved from the
database improperly. Stored Comments/Reviews were being stored inproperly too.
* Add Review: No longer possible to submit an empty review. User review must
be more than a determined length in order to be accepted.
* Search: Didn't always search every device, miscount device error.
