Aktuelle Zeit: 14 Aug 2026, 19:20
BeitragVerfasst: 03 Feb 2013, 15:01
03.02.2013 HollyPaint V1.0 [OS3, OS4, MOS, WOS + AROS]
Matthias Rustler hat mit HollyPaint ist ein einfaches Malprogramm erstellt,
was unter OS3, OS4, MOS, WOS + AROS läuft.
Zum Thema im Englischen Forum/on topic to english forum
BeitragVerfasst: 04 Aug 2013, 18:58
04.08.2013 HollyPaint V1.1 [OS3, OS4, MOS, WOS + AROS]
Änderungen in V1.1:
* Rebuilt with Hollywood 5.3
* Fixed issues with running stable under AROS, Morphos and AmigaOS4
* Colorwheel with alpha sliders in own window
* Individual setting of color for gradient, shadow and edge
* Made toolbar window resizable
* Loading and saving of transparent brushes
* Implemented remaining filters
* Implemented Arc tool
* Added command line options -v (verbose) and -vv (very verbose)
for debug output
* New brush functions:
- Trim brush (cuts off transparent areas)
- Invert brush
- Invert mask
- Invert alpha
- Replace Background by Pen color
- Replace Pen by Background color
- Copy Canvas: creates a brush from whole canvas
- Put Back: place brush at given coordinates
- Implemented reverting of brush
* Print hotspot offset in brush information window.
* User borderless display. This makes it possible
to load pictures with the same resolution as the screen.
* Print the size of the picture if it is too large to be opened.
* Added a checkmark to the status bar which shows
if a brush is active.
* Use checkmark instead of text objects to show mask and alpha state.
