Aktuelle Zeit: 26 Jul 2026, 01:56
BeitragVerfasst: 13 Jul 2014, 13:36
Änderung in AmiBlitz3:
13.07.2014
[r467] (HEAD) by tomsmart1
Blitzlibs
- added arc.bin this makes vallib.ab3 compiling again
[r466] by tomsmart1
Copyed exes and compiler Source with the extention _noFPU for testing!
Compiler:
- revert back changes because it make problems with PED editing on systems
with a FPU
update exes
10.07.2014
[r465] by tomsmart1
Compiler:
- added checks for FPU optimized compile for Functions and Statements
new exes of Compiler and PED for testing
[r464] by tomsmart1
PED:
- replaced Val() with Vallong() for FPU independens
PE_Tools.include
[r463] by tomsmart1
Compiler:
- replaced a wrong constant
BeitragVerfasst: 20 Jul 2014, 17:11
15.07.2014
[r468] (HEAD) by tomsmart1
Compiler:
- added check for types convertions and function call as >=7 parameter of a
function or statment call
- added exeption for True and False Token for the >=7 parameter check
new exe
BeitragVerfasst: 28 Jul 2014, 18:15
23.07.2014
[r470] (HEAD) by tomsmart1
Compiler:
- removed the 2 now unneeded Errormessages
new exe
[r469] by bernd_afa
fix when a function is called as parameter in function larger 6
BeitragVerfasst: 26 Okt 2014, 20:19
Änderungen in AmiBlitz3:
04.08.2014
[r472] (HEAD) by tomsmart1
Compiler :
- Bernd fixed the typecheck for pointers
new exe
31.07.2014
[r471] by derwanderer
Added support for the DebugTrap function in the "Emulated PED" in CLI Mode => Debugger can show variable's content when AmiBlitz3 runs in CLI Mode.
BeitragVerfasst: 26 Okt 2014, 20:20
2014-10-04
[r474] (HEAD) by derwanderer
Small Update that removes the "Can't convert types" compiler error.
[r473] by derwanderer
AIDE and NTUI update
AIDE supports now several screen layouts
Help support is currently disabled... will fix later
2014-10-08
[r478] (HEAD) by tomsmart1
Include
rastport.include.ab3
- fixed rp_Create{} for CGX
[r477] by tomsmart1
NTUI
rastport.ab3
- fixed _ntui_CreateRastPort{} for CGX
AIDE
- fixed the doublebuffer drawing of the images under CGX/MorphOS with the
above fix
new exe
[r476] by derwanderer
Recompiled AIDE
Small initialization fix in ntui_AddListItem
2014-10-05
[r475] by tomsmart1
PE/wizard_colorwheel.include
- fix/change the path of the gadgets to support MorphOS
PED:
- added a window look for the IDE Settings window if the Colorwheel and the
Colorboxes are drawn to prevent page switches in that time.
- to the above include change the colorwheel and the gradientslider work
under MorphOS now.
new exe
BeitragVerfasst: 26 Okt 2014, 20:21
2014-10-10
[r479] (HEAD) by tomsmart1
Include
- changed rp_Create{} to use the flags from a sourcebitmap too and if no
sourcebitmap the depths is set to 32 because we need Alpha
NTUI
rastport.ab3
bitmap.ab3
- same changes as above for rastport creations
AIDE
new exe
BeitragVerfasst: 26 Okt 2014, 20:22
2014-10-21
[r482] (HEAD) by tomsmart1
PED
- moved the adding and removing of the menu for WZ windows in 2 Statements
new exe
[r481] by tomsmart1
PED
new exe
[r480] by tomsmart1
PED
- fixed Menu adding and removing for WZ windows this fix a crash under MorphOS
new exe
BeitragVerfasst: 03 Nov 2014, 18:51
2014-10-26
[r489] (HEAD) by tomsmart1
Tools/AB3LibsManager
- refactored the source to remove double code
- added a number to the backup file name to have a backup for every write
new exe
[r488] by tomsmart1
Updated sourcecode ElmoreSysLib Blitzlib for the last commit.
[r487] by tomsmart1
BiltzLibs/Userlibs/ElmorSysLib
- copied Null function to function ID 20 of the BlitzLib
- renamed old Null function to StrToAdr to make it work again
new obj file
new DefLibs file
Compiler
- changed TokenID to overwrite form old Null to new Null Token to make StrToAdr
working
new exe
Update the corresponding Docs and the tokeninfo files.
A update of the Instruction index is needed if you only copy over the updated
files!
[r486] by tomsmart1
PED
- added functions to lock and unlock all open WZ windows
- changed "create minimized exe" to use the new functions so that only the
compilerstatus window is active
new exe
[r485] by tomsmart1
PED
- added the remove of the menu for the source window if the pointer switched
to busy and readded it if the pointer switched to normal
new exe
[r484] by tomsmart1
PED
- fixed finaly the sometimes happend endless compile runs with
new exe
BeitragVerfasst: 09 Dez 2014, 20:54
08.11.2014
[r494] (HEAD) by tomsmart1
Includes:PE/wizard_tools
- added a check for the uesd window to the PopUp-Window funktions the update the window this fix som problems with PEds intellisenes
PED:
- fixed a crash of the intellisens PopUp window with the change of the wizard_tools.include that was introduced with the change of the activesourcewindow function in R492.
- added the menu to the HelpDiag-window
new exe
07.11.2014
[r493] by tomsmart1
Compiler:
- merged the CPU CacheClear functions also added method with CacheClearE and make it selectable with compilerswitches
- set CacheClearE as the new default method for clearing the CPU Caches this fix the slow compiles on MorphOS
new exe
[r492] by tomsmart1
PED:
- added the Lock and Unlock of all open WZ Windows and Sourcewindow to all functions with no global event handling
like Projekt-, IDE-Stettings-, Menu-Edit-, Calculater-, CLI-Argument-,Compiler-Settings-, Rebuild of Commad
index- and Aboutwindow.
- added the activation of the Sourcewindow after closing this windows.
- cached the basic activation function for the Sourcewindow that it is the used window too.
new exe
[r491] by tomsmart1
PED:
- changed Library window to show TokenID in DEC instead of HEX
new exe
06.11.2014
[r490] by derwanderer
Recompiled AIDE exe and dbg.
12.11.2014
[r498] (HEAD) by tomsmart1
PED:
- added the reduce of the allowed IDCMP-Flags and Event for the sourcewindow if is set locked and the restore of the flags if the sourcewindow is unlocked
new exe
[r497] by tomsmart1
PED:
- deactivate and some unused code and removed some unneeded code
- added a Lock of all other windows for the Print (window) function
- added the new macro "setregsformenuexit" and added it to all Menufunctions that use Basic
This fix and remove event repeats if the Sourcewindow was locked and a event for it happend like
resize of the window.
new exe
[r496] by tomsmart1
PED:
- set/fix for all windows that get no Menu added the Flag "RMBTrap" in PED.wizard this fix the crash
under MorphOs if the right Mousebutten get pressed if one of this windows are active.
new exe
11.11.2014
[r495] by tomsmart1
PED:
- fixed "Jump to Sourceline window" to allow to jump to sourcecodeline 1
- added lock and unlock of all other windows for jump to sourceline window
new exe
BeitragVerfasst: 09 Dez 2014, 20:55
18.11.2014
[r501] (HEAD) by derwanderer
Made NTUI/main.ab3 compile again
16.11.2014
[r500] by tomsmart1
Removed noFPU Version because they doesn't work and I have no time to fix it !
15.11.2014
[r499] by tomsmart1
Tools/Ab3AutoDocViewer
- push Version to 2.0
- change the detection of the function nodes end
- renamed variables to get rid of $ in the name
- fixed the count of the function indexnode to support the full 256 possible nodes entrys
- change the node scan that only the known nodes are tested
- remove double scan for the entry if it selected via GUI
- added scan of the complete file for function nodes that are NOT in the TABLE OF CONTENTS and if there is no table
- made the autoscan switchable via Tooltype and cli arg
- change the detection of the keywords and expand the keyword list
- added the (un)lock of the window
- removed double versionstrings
- moved code to subroutines to remove double code
- fixed the use of the windowsettings via CLI
- fixed app drop new exe + update Icon Docs/AmigaLibs/wizard1.doc
- fixed function node marker so Ab3AutodocViewer are now able to detect the end of the node and sthe start of the next
BeitragVerfasst: 09 Dez 2014, 20:59
30.11.2014
[r502] (HEAD) by derwanderer
Added class scan functions to NTUI
Added NTUI folder to "Examples", including hello world, an application and a demo to list classes
BeitragVerfasst: 09 Dez 2014, 21:00
04.12.2014
[r503] (HEAD) by blackab3
- improve image.include.ab3 and png.include.ab3 to use ab3support.library now.
- Change Tools/AB3FDConvert to use new pathes of Amiblitz3.
- New Deflibsfile to use new converted muimaster.library1 V3.9
07.12.2014
[r506] (HEAD) by tomsmart1
NTUI Includes:
- freed some space on deinit/exit
- changed to use pooled mem for .str to reduce memory fragmentation
AIDE:
new exe
AB3Scan:
- added free stucture of the parser at exit
new exe
[r505] by tomsmart1
NTUI includes:
- changed used includenames form .bb2 to .ab3
- set some pointers to Null after they are freed
- freed used prefixtree at exit
- add check for Nullpointer access to ntui_FreeObject{}
[r504] (HEAD) by tomsmart1
NTUI includes:
- replaced #NULL with Null
- added all.res in some includes recompiled AIDE
