Aktuelle Zeit: 09 Sep 2026, 10:30
 Betreff des Beitrags: WinUAE 1.1 released !
BeitragVerfasst: 02 Okt 2005, 21:07
Falls es sich noch nicht rumgesprochen haben sollte:
(für diejenigen, die auch emulieren. (vermisse die Emusparte hier)) :D
WinUAE 1.1 (02.10.2005)
Major bugs introduced in 1.0 fixed:
- Picasso96 graphics corruption after ALT-TAB
- Zipped Amiga Forever Kickstart ROM image decryption problem
- JIT FPU ACOS bug (incorrect result if argument was negative)
Older bugs fixed:
- More stable on the fly configuration loading
- In windowed mode Amiga window height was sometimes slightly
larger than requested size
- "the desktop is too small for the specified window size"-check
was not completely correct
- AHI recording mode memory leak
- Some Amiga monitor drivers work now properly (for example Euro36)
- Incorrect paths if WinUAE was run from networked drive
- Some custom chipset emulation bugs (Obliterator intro, Elfmania
scoreboard, Warp and others)
- Directory filesystem directory modification date bug if comment
or protection flags were modified
- Improved directory filesystem compatibility
- Rare disk emulation bug introduced in 0.9.90
- Action Replay statefile restore bug introduced in 0.9.90
- OCS/ECS color translation to native colors fixed. (this was bug
since the beginning of UAE..) Colors are now slightly brighter.
No effect on AGA-mode colors.
New features:
- Configurable Catweasel joystick support, MK4 mouse support added
(NOTE: Right and middle mouse button may not work with all mice,
requires Catweasel driver/firmware update)
- MMKeyboard support added
- Transparent "drive led status bar"
- SPTI (Windows 2K/XP) SCSI emulation includes non-CDROM SCSI devices
- Improved uaescsi.device SCSI interface selection
- Custom emulation updates (Death Trap, Loons Docs, Spanish Rose by
Creed, Filled Perspective by Zero Defects, Himalaya by Avalanche..)
- Improved default path setting, Amiga Forever 2005 paths supported
- More missing keycodes added to input-panel
- Copper debugger: tracing, single step and breakpoint
- Disk swapper: right button doubleclick in "Disk image"-column:
removes disk in disk swapper panel. right button singleclick in
"Drive"-column: remove disk in drive
- New-style ROM config entries
- Compressed hardfiles supported (limitations: max 100MB, all written
data will be lost after reset or exit, hardfile file name extension
must be either hdz, zip, rar or 7z)
- Hardfile drag&drop to harddisk-panel
and more..
DL: http://www.winuae.net/
BeitragVerfasst: 02 Okt 2005, 21:59
Abend HOL2001
Ist aber noch nicht offiziell raus, zumindest noch nicht upgedatet worden auf der WinUAE Homepage. Da ist noch der Stand vom 11.09.2005.
Aber ich denke, das updaten wird in den nächsten Tagen geschehen.
Ich emuliere auch noch und warte auf die neue Version, obwohl ich seh grad, das im download Bereich die Version 1.1 der Installer und das Zip-Archiv schon zur Verfügung steht. Da werd ich mir das doch gleich mal runterladen :) .
BeitragVerfasst: 03 Okt 2005, 15:45
Hmm, komisch, bei mir ist alles auf dem neustem Stand :?:
Leere mal deinen Cache ! :D :wink:
BeitragVerfasst: 03 Okt 2005, 20:28
Hi HOL2001
Hab ich gerade gemacht, mir wird dennoch auf www.winuae.net unter News der Stand vom 11.09.2005 angezeigt.
Mmhhh, muß man das wieder verstehn :?:
BeitragVerfasst: 04 Okt 2005, 19:58
Emulieren ist zwar schön und gut. Aber Amiga live zu erleben kann das nicht ersetzen. Obwohl es sogar Emulatoren gibt die den Ton von Diskettenlaufwerk auch emulieren. Amiga Classix machts das zum Beispiel. Das steckt UAE hinter glaube ich. Problem ist halt nur der Platz den man zusätzlich braucht, um die Kisten aufzustellen. Dann ist ne Emulation immer gut, wenn man mal schnell einen kleinen Zock machen will.
BeitragVerfasst: 04 Okt 2005, 23:05
Hallo Mystique
Eine Emu kommt mit Sicherheit nicht so gut wie ein Original, aber die kommt dann gut, wenn man in die Amiga"Preiszange" genommen wird oder auch nicht den Platz für einen PC und einen Amiga hat.
Ich hab noch beide vereint nebeneinander auf meinem Schreibtisch stehen. Nur haben beim Amiga die doch hohen Kosten dafür gesorgt, das ich irgendwann dann doch, mir auch einen PC geholt habe und diesen mit den Emulatoren AmigaOSXL und WinUAE ausgerüstet habe.
Bin aber immer noch an einem Original Amiga interessiert, aber in der Preisklasse vom Peg und weniger die vom neuen A1.
