Aktuelle Zeit: 30 Sep 2026, 03:38
 Betreff des Beitrags: extrainfo V1.2 (17.07.2007)[OS4]
BeitragVerfasst: 06 Nov 2010, 00:16
17.07.2007 extrainfo V1.2
Mit extrainfo erhält man zusätzliche Informationen über Dateien.
Extrainfo wurde mit Hollywood 2.5 von PEB erstellt.
Benötigt jhead.lha
History:
Version 1.2 (7/17/07):
*Fixed the "bug" that showed up when starting multiple instances of ExtraInfo,
which means that now the "Multiple" switch in ContextMenus can be used, and also
"drag and drop" can now be used if ExtraInfo is used through AmiDock.
Version 1.1 (7/14/07):
*Updated the ReadMe.
*Added an explanatory message (in place of the error message) if ExtraInfo is
started without having any files selected.
Version 1.0 (7/13/07):
*First attempt.
